Results 1 to 9 of 9
Thread: SLR valve clearance
    Daz Max's Avatar
    Daz Max is offline Mr Impulsive
    Apr 2007
    Godalming,Surrey
    SLR valve clearance
    Can anyone let me Know the valve clearances for the Slr?
    Daz
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Re: SLR valve clearance
    If they're the same as a domi (RD02);
    inlet 0.10mm (0.004 in)
    Exhaust 0.12mm (0.005 in)
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    SLR clearances are 0.10 for inlet and exhaust according to my workshop manual
    but dont forget the decompressor will hold the right exhaust valve down, so you need to wind the engine anti clockwise to the T mrtk on the flywheel viewed through the hole in the flywheel cover to stop this
    merv
    Daz Max's Avatar
    Apr 2007
    Godalming,Surrey
    Thanks for that peeps
    I can crack on with my Hybrid Xr lump thats been sitting waiting to be built up .
    Daz Max's Avatar
    Apr 2007
    Godalming,Surrey
    Thanks for the decomp advice Merv
    Oct 2008
    UK
    I'll ask about the valve clearances in this thread as well... (twice as likely to get a reply :P)
    What are the valve clearances on the FX650?
    And are the valves shim over bucket, shim under bucket, or thread adjusted?
    ta in advance.
    Mervinh's Avatar
    Nov 2006
    same as vigor and slr at a guess, screw type adjusters,
    merv
    Oct 2008
    UK
    The FX650 Vigor (not the FMX)
    I did wonder if they would be the same as the SLR seeing the FX was an updated SLR, but then again, that would be logical :P
    Screw type adjusters...thats good new :P
    Shims are expensive :S
    Mervinh's Avatar
    Nov 2006
    aha me seeing m that are not there, yes vigor will be the same i am sure
    will check to see if is in the handbook when i find it
    merv
  1. Valve Clearance XL650 2005
    By boomer84 in forum Transalp
    Last Post: 03-03-09, 01:26 PM
  2. exhaust clearance
    By moon in forum Transalp
    Last Post: 29-07-08, 10:22 PM
  3. TA650 recommendend valve clearance
    By transalper in forum Transalp
    Last Post: 24-05-08, 01:49 PM
  4. Quick question about valve clearance
    By darthDassie in forum Africa Twin
    Last Post: 28-11-06, 09:46 AM
  5. VALVE CLEARANCE
    Last Post: 26-04-06, 08:38 PM
