flywheel removal
hi guys has anyone removed the flywheel on there dominator fmx etc, i have to change my starter clutch , in the manual they use a special tool to stop it from spinning but i don't have access to this tool an rather than buying one just for one job , is there a cheaper tool on the market or another method of locking the flywheel to undo the nut without damaging it . any advice would be greatly appreciated ..
edit ; i found a thread where someone had used a nylon ratchet strap rapped round the flywheel a few times so the bolt is now out ,now i just need the thread size for the fly wheel puller any one know the size ? or a bolt off something else which would do the same job ? Last edited by explore; 21-05-09 at 07:36 AM. |
Re: flywheel removal
Sorry, Not had any experience on these bikes doing that.
I have a flywheel puller but it has three arms which are used to grab it and a bolt in the middle which you turn to pull it off. I think this is a different tool than the one you are looking for. I do remember having one that screwed in the centre which I had for a fsie many many years ago. i just had a look but cant find it. I'll keep looking though. Where did you get your workshop manual from I've been looking for one with no success. Pash |
hi pash , yeah its the type of tool that screws in the centre of the flywheel , i may have to try a traditional puller if i cant find a bolt to fit , regards to the manual i downloaded it off the net a few years ago believe there's a link to it on this site
Quote:
http://www.eikholt.net/hpalt/dommi/ |
Flywheel puller - £22 from Silvers - at that price it's worth buying, it's a multi-fit tool so it will always come in handy.
Flywheel locker (to undo the centre nut) - a wee bit more from Silvers! - dunno about you, but I can't justify that sort of expense, so I just used a strap wrench and some old towelling to wedge the flywheel in position. You're welcome |
When i removed mine on my xr400 i screwed the oil filter bolt from a 250 superdream into the centre hole and then smacked the head of the bolt with a big hammer and the shock made the flywheel jump off
__________________
HONDA VARADERO 99. NWS HUGGER, SCOTTOILER, HARD WIRED GPS, HEADLIGHT PROTECTOR, HEPCO @ BECKER LUGGAGE, GIVI CRASHBARS, GIVI TOP BOX, AUDICATOR BRAKE TEXT UNIT HONDA XR400RY 1999. CLARKE LARGE TANK, EARLS LINES, DISC & FORK PROTECTOR, TRAIL TECH, ACERBIS DISC & FORK GUARDS GASGAS EC250 2004 FAST AS F**K FMF FATTY PIPE WITH POWER CORE 2 MITSUBISHI L200 WARRIOR 2004 IN BLACK
Hi
You can buy a drawer but I used a wheel stud from a truck These are a standard size and threadon 95% of HGV trucks, I think its about 22mm but just screw it in the flywheel and turn it tight with some grips or stilsons and tap the flywheel and it comes off. Ken Quote:
thanks for all the info guys .
Ive now removed the flywheel just awaiting the arrival of the new starter clutch ($75AUD) an gasket ($20AUD) from Honda , so with the aid of a cheep Chinese ratchet strap ($16AUD) an a lorry/truck wheel stud,, 22mm x 1.5 thread (free from a friendly truck mechanic ) thanks for the info on that kenny1950 . its turned out to be a relatively cheep an simple job, the parts should be hear today, ill let you know how i go putting it back together . |
| Bookmarks |
| Tags |
| flywheel, removal |
| Thread Tools | |
| Display Modes | |
| Anyone got a flywheel bolt removal tool? | landyandy | Africa Twin | 4 | 01-05-07 01:55 PM |
| Seat removal? | newtwin | Africa Twin | 7 | 21-02-07 07:54 PM |
| increased flywheel weight for even smother running | raymo | Chatter | 1 | 10-02-06 09:17 PM |
| Frame removal | Tornado | Africa Twin | 16 | 10-01-06 05:33 PM |
| Removal of wheels | jvaughan | Africa Twin | 10 | 07-07-05 12:32 PM |
