Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: Kickstart
  1. #21
    MadWelshBiker's Avatar
    MadWelshBiker is offline Motosport XL250 K1
    Aug 2007
    Caerphilly, South Wales
    Re: Kickstart
    Bump starting is fine if you have a hill to run down but if you are on the flat or at the bottom of the hill it is hard work. I have always bump started bikes in 2nd or even 3rd gear but the NX just wouldn't pick up in 2nd. It went striaght away in 1st but took of like a cat with it's nuts in a blender.
    Never mind TT coming up. I'm going over for the first time and am looking forward to it. Just hope I can get my bike back together by then.
    Mike
    tractot4play is offline Member
    Jan 2009
    belfast
    Re: Kickstart
    Quote Originally Posted by IgorVigor View Post
    Hi.
    Would it be possible to fit a kickstart to the FX 650 Vigor?
    Just been thinking about it, as I take the bike offroad a bit and last thing I want is a non start because of a dead battery. (It never sounds like it will start anyway...always does though, after a spin or two)
    I dont know if the SLR had a kickstart?
    The dommie did though and being the basically the same engine I just wondered...
    Thanks in advance
    yes you certainly can add a kickstart.its been done before and i intend to do it myself to a slr motor that i am transplanting to a old xl.you need to split the crankcases so a full strip down.goodluck tractor.
  4. #23
    Jan 2009
    belfast
    Re: Kickstart
    Quote Originally Posted by tractot4play View Post
    theres a full write up on the parts you need and how to sort it out on thumpertalk.its a lot of work but in my opinion well worth it.all dual sports should have a kicker.infact the dual start lm i have i do not use the button as i prefer to kick it over...goodluck
  1. xr 400 kickstart lever needed
    By johnniep in forum XR
    Last Post: 19-06-08, 09:57 PM
  2. new kickstart
    By sheep911uk in forum XR
    Last Post: 15-03-08, 08:51 PM
  3. kickstart problem
    By woodyc in forum XR
    Last Post: 02-02-08, 05:00 PM
  4. Broken kickstart shaft
    By mazmick in forum XR
    Last Post: 05-05-07, 01:03 PM
  5. xr 250 kickstart
    Last Post: 31-03-07, 09:38 PM
