I need suggestions for new grips ..
The current are the original Honda , and with the summer heat becomes very soft and sticky , plus they made my hands black .
I need open type ones , as i have Handlebar ( protectors) .
Any suggestions ?
Any suggestions ?
I was going to say fit heated grips and be done with it, then noticed where your posting from. Doh
Most grips come with closed end but with a sharp knife you can trim the end caps off with no problem, how are you for stockist in Greece or are you after mail order?
top right of your screen are the forum links all the normal recommended are listed there
Accessories - Honda Trail Bike Forum Links Directory
Well so far I am looking at Renthal and Motrax ...
I found the " Motrax Tyton Grips 125mm Open " as a positive solution .
What I care most , are to be a high quality long lasting solution.
And about thermal grips ... yes at my location they are not a high priority .
