Re: SLR weird Oil Leak
There should be no oil in the headstock tube. If it's actually coming from inside the headstock tube itself, it must be escaping from the part of the frame that is used as an oil tank. That means there is either a crack in the headstock or a crap weld somewhere that's not oil tight.
Now, if the dipstick/filler area is oil free and it's not getting out of there, it may be best to remove the forks and yokes and then start it up to see where it's coming from. Once it's tracked down, a blob of weld or even JB Weld may do the trick depending on the cause.
It's very puzzling
