Results 1 to 8 of 8
Thread: well how long will this last
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Been getting some clicking noises from the front wheel when i push the Vigor backwards into the shed, went out for a nice ride today and speedo died on me flicked up and down then was ok for a while, was in barnstaple so thought drop in and raid my mate Phils stash of cables at his breakers, he was not in so failed there, So came home and attacked it, turned out it was the plastic drive wheel in the speedo drive had broken up, so looks up part numbers cog available on its own £17.30, complete speedo drive £18.20 + vat numpty on ebay £20+ £7.50 postage secondhand, now bike is outside shed sans front wheel now and it is gonna be a while before i can get the new drive, do i put it back without the gear, hang i have some genuine loctite superglue bought in a french hypermarket, that is supposed to be better than it is here, as supposedly the french do not stick each other to bog seats etc with it,
    clean it up with carb cleaner, glue it back together file out the overspill glue after it had set, reassembled and it is working fine so i am gonna see how long it lasts new drive is on order from lings with a new cable £13.50
    Merv
    switch's Avatar
    Feb 2009
    Romania
    Re: well how long will this last
    I've gone 6 tankfulls of gas (1200km give or take 200km) without a working speedo/odo. For me a new drive cog is about 20e; sadly I can't afford it these days...
    Mervinh's Avatar
    Nov 2006
    do you have speed cameras in Romania??
    the speedo drive is cheaper than the fine for speeding here
    Merv
    switch's Avatar
    Feb 2009
    Romania
    Quote Originally Posted by Mervinh View Post
    Merv
    Who needs one?
    Cheapest speeding ticket is at least 10 times the cost of a new speedo Cog indeed.
    As long as I don't surpass 3500k RPM in 4th I'm ok in the city. Outside, 4,5k RPM in 5th is the limit. On the freeway I'll hate riding before I get fined (should hold a steady +6k RPM in 5th which is a bit much for my linking) And as you saw, I have a pretty simple way of judging km
    Oct 2008
    UK
    havent you got a cheap bicycle speedo somewhere in the shed?
    would do for a minute :P
    EDIT: You have made me wonder though :S
    Is that what is wrong with my speedo.. :S
    Occasionally, the needle will start bouncing around... very random, and at no definative speed either...
    it happened on friday...40mph and then the speedo started bouncing from 35mph to 45mph :S...stopped for a junction and it was fine again
    Mervinh's Avatar
    Nov 2006
    Igor
    get the front wheel off and check the drive is not seizing up mate, does it click when you wheel it backwards mine was
    merv
    Oct 2008
    UK
    I dont think it clicks...
    I was going to take the wheel off soon to have a nosey...
    Good luck with yours...
    Mervinh's Avatar
    Nov 2006
    mine was in 3 pieces by the time i got it apart, the 2 drive lugs were broken off and the cog was cracked , sooner rather than later maybe good for yours
    merv
  1. iridium sparkplugs, how long is to long?
    Last Post: 16-03-09, 11:48 PM
  2. Not long now
    Last Post: 05-08-08, 05:22 PM
  3. At long last...
    By Mudwiz in forum Chatter
    Last Post: 15-04-08, 04:42 PM
  4. Off they go on the Long Way Down
    By Cie in forum Chatter
    Last Post: 14-05-07, 08:14 AM
  5. Long way down
    By barryw33 in forum Chatter
    Last Post: 30-04-07, 02:15 PM
