If the tank cover is unstable, offroad riding WILL be a problem. If you tour a lot on-road without venturing off the tarmac, then a tank cover is fine. Otherwise it can lead to serious problems. You need a firm grip on the tank when the going gets tough; if the material isn't perfectly fixed to the tank, you'll have control problems. It would be like mounting 7/8 inch handlebars in 1 1/8 in mounts!
