Results 1 to 7 of 7
Thread: Domi won't start in gear with clutch in
    Old Man on a Bike is offline Junior Member
    Jul 2009
    Scotland
    Bought my '95 Domi a couple of weeks ago. First bike. Thoroughly enjoying it..
    Problem is that it now won't start in gear with the clutch in (as I found out when it stalled in the middle of a junction the other day) whereas it used to do it fine. Starts fine in neutral but nothing at all when in gear and clutch in.
    I had been fiddling with the clutch cable adjuster, at the lever end, the other day and wonder if that has anything to do with it.
    Any advise about where to start looking for the problem would be welcome.
    scarfacehugo's Avatar
    Jul 2008
    London
    Re: Domi won't start in gear with clutch in
    The clutch lever should have a switch and its probably gone. Follow the wire and check if the plug's connected.
    If it is, replace the switch. Simples
    Jul 2009
    Scotland
    Quote Originally Posted by scarfacehugo View Post
    Thanks.
    Will check it when I get home on Friday.
    I could hear a click when I pulled the clutch. I guess that would be some sort of relay so must be physically connected, will try and find it and check the electrics at weekend.
    Quote Originally Posted by Old Man on a Bike View Post
    Thanks.
    The switch may be clicking but it's quite easy to knock the connectors off of it when adjusting the cable. When putting them back on make sure the brass connectors are actually on the spade terminals rather than just the plastic sleeve sliding over it.
    ROCKOZ's Avatar
    ROCKOZ is offline Grown up member ;)
    Dec 2008
    South Bedfordshire
    Mine does it all the time because I get mud in the bit at the stand end which prevents the switch from working...
    Lumiya's Avatar
    Ziost
    Also the pads on the switch internals get oxidized with age, the switch still clicks but no voltage/current flows.
    Jul 2009
    Scotland
    Problem solved. One of the spade connector things was disconnected. Stuck it back on and Bob's your uncle.
    What kind of fool am I. To be honest I hadn't even noticed the electrical cable when I was looking before.
    Thanks for all the help. Good to know that thee are so many knowlegable people around that a total bike newbie can call on.
    Thanks again.
  1. Replies: 5
    Last Post: 02-12-11, 03:07 PM
  2. Replies: 8
    Last Post: 17-04-09, 12:30 PM
  3. Domi Newbie
    By rikki1q in forum Dominator / FMX
    Last Post: 20-01-07, 04:00 PM
  4. Who said that Domi was not amphibian ???
    By lreal in forum Ride Reports and Pictures
    Last Post: 18-05-06, 08:54 AM
  5. Carb for 97 Domi
    By Frayed Dave in forum Dominator / FMX
    Last Post: 02-05-06, 07:41 PM
