Results 1 to 3 of 3
Thread: Front Brake
    crp47 is offline Member
    Feb 2009
    Jersey C.I.
    Unhappy Front Brake
    How in hell can I get the hanger pins out of the front caliper without butchering them as they don't want to budge or so it would seem? HELP !!!! CLIVE
    Daz Max's Avatar
    Daz Max is offline Mr Impulsive
    Apr 2007
    Godalming,Surrey
    Re: Front Brake
    Soak in WD40,then a couple of sharp whacks with an impact driver.
    switch's Avatar
    Feb 2009
    Romania
    Re: Front Brake
    Quote Originally Posted by crp47 View Post
    Bathe in WD40 or some other spray designed to loosen stuck bolts (don't know the proper name in English) - just spray a LOT, no need to remove the caliper. Leave to dry and repeat a few times.
    After that, get a good quality tool (screwdriver, allen head or w/e), make sure it's the exact proper size (specially for screwdrivers!!) then try to loosen it. Force it a bit both way if it won't give in, and bathe again in WD40 or anti-grip spray.
  1. Front Brake Discs.
    By 1gear1brake in forum Africa Twin
    Last Post: 05-06-09, 05:05 PM
  2. Front Brake caliper
    By vinas in forum Africa Twin
    Last Post: 18-02-09, 12:16 PM
  3. spongey front brake
    Last Post: 01-09-08, 12:07 PM
  4. Front brake caliper
    By russellt in forum Africa Twin
    Last Post: 06-03-08, 10:50 AM
  5. Front brake noise
    By jollyrodger2005 in forum Dominator / FMX
    Last Post: 16-08-06, 11:38 PM
