Thanks for the kind offer Dave.....I had forgotten about the Araldite fix for pitted forks.
I do have a compression tester myself; again thanks for the offer, but wondered whether there was any known weak points with these engines with regards to valve stem seals or the valves themselves.
The fact that the smoke is only being emmitted from one exhaust kind of leads me to valve seals rather than piston rings which would probably result in smoke from both exhausts.
Anyone shed any light on what the cause probably is?
Darren
