Further upgrading was cut short as 2 days into installing my new long-range-tank, a jeep decided to plow at 40mph into my left flank. Damage to the bike:
- rear side fairings chopped up; mounts broken
got new parts
- rear tail fairing cracked
repair and repaint coming up
- rear undertail frame bent
visual misjudgement due to cracked number plate mounts
- slight undertail frame misalignment (only frame part that suffered any damage)
note to self: inspect eyesight soon; no actual damage there
- front fairing forwoard mounts snapped
repair and repaing coming up
- front fairing + windshield missing (thanks to the kind of people that give Romanians a bad name); bot pieces were pretty chopped though
police came through -- one of the cops apparently took them from the scene
- front mounting bracked slightly bent
it's hammer time!!! fixed.
- headlight all messed up (broken mounts, mirror and glass
- rear footpegs bent to hell and back; right top mount slightly bent
- front right footpeg bent; what the flack!?
new part underway
- number plate and rear headlight broken
new parts underway
- topcase... can be carried in a purse -- no piece larger than 5x5 inches remains
- rear caliper damaged, unsure exactly where, because...
no damage to caliper; brake lever was bent and could only be pushed halfway; fixed
- bent swingarm; rawr
new swingarm from Germany for 100e including shipping and all swingarm accessories
- suspected damage to swingarm and rear shock bearings/brushings (if any)
fixed as replacement came with good-as-new bearings; still greased them
- bent handlebars; ever saw a Ranthal Twinwall BENT?
pro-taper contour
- throttle tube & grip damaged
new parts awaiting installation
- both mirrors broken (actually, the round mounts for the mirrors are missing...)
will have to buy a pair one of these days...
- one turn signal broken, two more with damaged housings (still 100% usable though)
replaced rear signals with LED based ones, replaced relay to cope with fast blinking
- slightly bent exhaust system; no it ain't the mounts, it's the cans themselves; fixable by reinforcing the weld around the mount and re-painting the cans
