After taking my dommie for some serious offroading, I decided it's time to move on to something more dirt-friendly. So the good ol' NX will be kept as a city & gravel bike.
That's how my project starts. Over the next months, depending on available cash, I'll slowly work on my dommie, improving it bit by bit.
The first major improvement was installed this weekend: my very own DIY hydraulic clutch kit. I took a brake pump, reservoir, lever and mounting from an old scooter and bought a used rear brake pump. This, together with a thick piece of metal, some nuts and bolts and about half a bottle of brake fluid got me rid of the clutch cable. There's still a little work to be done, but I'll finish it this weekend (some loose ends with the choke, handguard and the need for a chain roller.
Pictures: Picasa Web Albums - Dorian - Honda Dominat...
The installation is pretty simple, if you've ever worked hand on with braking systems: take the rear brake pump, open it up and remove both the small valve at the rear end the spring within the pump. Polish the screw thread on the rod that normally connects the brake pump to the brake pedal. Exend the rod somehow (either leave 1/3 inches of thread on the end of the rod or use welds), taking special care to keep the rod as straight as possible. The end of the rod needs to be threaded with a 5mm thread (I think), so as to fit the small coupling at the end of the clutch arm on the crankcase. This entire assembly will work as your clutch piston. It needs to be mounted somewhere behind the passenger footpeg, behind the airbox and as high as possible. You wouldn't believe how far up the chain goes...
The mounting is a 4mm thick piece of steel which I chopped & grinded to shape. I welded two 13mm nuts onto the piece and replaced the stock footpeg screws with longer ones, so they could grip the steel plate as well. The clutch piston is fixed with two regular screws onto the plate. That's the whole deal.
The master cylinder for the clutch is pretty simple to install - just remove the clutch perch and replace with the one from the scooter. I'll have to machine a small mount for the choke cable & left mirror, but that will be done fairly soon - just need 2h of work.
If anyone's interested, I'll provide details on the whole operation.
The result is a cable-less, maintenance-free solution that feels pretty much like the stock clutch, except much smoother (almost like a brand new, oiled cable).
