Results 1 to 5 of 5
Thread: nx650 etc /xl600 fork legs. Interchangeable?
    krypton is offline Member
    Mar 2009
    essex
    Are these interchangeable?
    I prefer the dommie style front mudguard. Already have a 19" wheel.
    Still want to use xl stanchions, as they can air adjusted.
    switch's Avatar
    Feb 2009
    Romania
    Re: nx650 etc /xl600 fork legs. Interchangeable?
    I think the legs are the same diameter on the outside. Wheel fittings are similar for old models, but I'm pretty sure the low mudguard can't b e fitted on XL/XR.
    Mar 2009
    essex
    Yes you're right, the low mudguard won't fit the xl forks (not without welding on mounts!), which is why I need to know if the fork stanchions are the same on the nx650 and xl. They are both 41mm diameter but I need to know if they fittings at the bottom are the same.
    To be clearer, will at set of XL600 fork stanchions/uprights fit into a set of nx650/transalp fork legs/bottoms?
    I believe the XL forks are more adjustable, which is why I want to keep the fork legs.
    switch's Avatar
    Feb 2009
    Romania
    Oh, you're trying to merge the two... just realised now, sorry. Not sure I can help you there. Try looking at a patrs listing (try Welcome to OEM Motorparts, Original parts for Aeon, Aprilia, BMW, Buell, Cagiva, Dinli, Derbi, Ducati, Gilera, Harley davidson, Honda, Kawasaki, KTM, Moto Guzzi, Peugeot, Piaggio, Suzuki, Sym, Tomos, Vespa and Yamaha motorcycles, mopeds and scooters.) and check to see if the forks have roughly the same listings.
    I honestly doubt it, since the lower end is where all the valving is for the NX forks. The XR/L ones are designed for air, so the valving should theorethically at least be different.
    Mar 2009
    essex
    Thanks for the site, not seen it before. Looking at the diagram of the front forks on the site, it appears the 2 are not interchangeable. Looks like I'll be sticking with the original mudguard for the time being.
  1. xl nx650 forks legs. Interchangeable?
    By krypton in forum XL
    Last Post: 02-09-09, 02:12 PM
  2. For Sale: Dominator nx650 or XL600 front brake disc (NEW)
    By Pistol_Pete in forum For Sale / Wanted
    Last Post: 18-08-09, 02:28 PM
  3. I can feel it between my legs :-)
    Last Post: 25-02-08, 08:23 PM
  4. troosers to fit my little legs
    By Chad in forum Clothing
    Last Post: 07-01-07, 11:24 PM
