Hi, I have just joined the forum and this is my first post - a mate who's emigrating has given me his french registered Dominator 650 (), which I eventually hope to register in the UK. I have decided to do a major renovation of the bike first as it has been unused and stored outside for over two years. Having bought a new battery, some fresh petrol and a can of easy-start, it now runs - however I have one or two questions!
First, how do I check the oil level? There's nothing showing on the dipstick when the engine is off, but shortly after running it, the dipstick is covered in oil. It then seems to dissappear.
Second, it will not run without the choke applied, even when the motor has warmed a bit. I have deliberately not got it really hot until I get the answer to question one, but I'm sure it should be able to run without the choke in the summertime, when the engine is warmed up.
Third, where's the neutral switch and do they fail often? Mine does not work - I have had to short the switch to ground to get the neutral light on and hence get the starter motor to spin.
Thanks for any answers in advance.
