Re: No Spark
Well if all those checks and replacement parts are ok it's got me stumped. I would replace the plug cap and HT lead cos they ate cheap and easy. Then if you can, start swapping bits with another bike.
Not much help really. Good luck though.
__________________
2001 Transalp XLV650 2007 Varadero XLV1000. Now you're torquing |
Re: No Spark
Quote:
__________________
HONDA VARADERO 99. NWS HUGGER, SCOTTOILER, HARD WIRED GPS, HEADLIGHT PROTECTOR, HEPCO @ BECKER LUGGAGE, GIVI CRASHBARS, GIVI TOP BOX, AUDICATOR BRAKE TEXT UNIT HONDA XR400RY 1999. CLARKE LARGE TANK, EARLS LINES, DISC & FORK PROTECTOR, TRAIL TECH, ACERBIS DISC & FORK GUARDS GASGAS EC250 2004 FAST AS F**K FMF FATTY PIPE WITH POWER CORE 2 MITSUBISHI L200 WARRIOR 2004 IN BLACK
Re: No Spark
I have just recently had the same problem! One of the block connectors on the cdi was loose.The retaining clip was worn allowing it to come out when the vibes of the motor shook it about and it only needed a to move slighty to break the spark
Re: No Spark
Have had another play around with it, still no luck, getting fed up trying to fix it in the rain so have decided to give up and a local bike shop will look at it tomorrow. I imagine it will probally be something really obvious.
will let you know how i get on. |
| Bookmarks |
| Tags |
| spark |
| Thread Tools | |
| Display Modes | |
| spark plugs | paulo | Varadero | 5 | 05-04-09 03:20 AM |
| XT-Z 660 spark plug help | shack | Yamaha | 0 | 15-11-08 03:14 PM |
| No Spark | sheep911uk | XR | 4 | 26-01-08 09:49 AM |
| SPARK PLUGS | Oxbone | Africa Twin | 17 | 05-09-06 12:26 PM |
| one spark or two | peter blackshaw | Africa Twin | 1 | 26-06-05 12:53 PM |
