Results 1 to 10 of 15
Thread: NX650 Starter Clutch
    SiNX650's Avatar
    SiNX650 is offline Member
    Feb 2010
    Cumbria
    Hello all,
    Recently got a 1989 NX650 Dominator.
    Having problems starting it with the button though, sometimes it does, most of the time it doesn't.
    My dad says it's the starter clutch that is the problem, it's not gripping properly, so we're after a fresh one if anyone has one spare or knows of one.
    Thank you,
    Simon.
    SiNX650's Avatar
    Feb 2010
    Cumbria
    Re: NX650 Starter Clutch
    Anyone know if the starter clutch from an XL600 or NTV650 will fit?.
    Thanks.
    Mar 2008
    Scarborough
    Quote Originally Posted by SiNX650 View Post
    Thanks.
    I'm having mine replaced this Saturday as having the same problem, starter clutch has two pieces to it (so the garage told me) one's about £90 t'other is about £50, plus a bit of labour.
    But that depends on what they see when it's in bits, it might just need a clean out etc, or it might need one piece or both.
    Worst case I reckon about £200.
    switch's Avatar
    Feb 2009
    Romania
    I can be the starter relay, the starter motor, the starter clutch. In this order.
    boroboy is offline Member
    Jan 2010
    croydon
    Also add to the posting above, It's worth double checking the battery state of charge and the block connector r/h side on frame that connects the h/bar switch..... I just did mine last week and found it full of green gunk, causing intermittant fault/short.
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    My SLR starter gear was full of oily mayonaisse gunk, i removed the gennny cover and cleaned it all up it was much better after that and no need to remove the flywheel either, took the opportunity to clean the starter connections at the same time
    Merv
    SiNX650's Avatar
    Feb 2010
    Cumbria
    Thank you for all the replies.
    We'll go through the suggestions and see it that helps. When it doesn't start with the button, it either sounds like the starter motor is spinning freely, or makes a grinding or shredding noise.
    Here is a pic of it:
    Thanks.
    AlanH's Avatar
    Bristol, UK
    That describes starter clutch failure exactly. It really is a very nasty unhealthy noise.
    Mar 2008
    Scarborough
    Yup ditto that..
    I'll post back once mine has been done, give you an idea of what to expect.
    Jan 2010
    croydon
    Thanks.
    Ah a better description of the fault, "press the starter button and it sounds like a sewing machine" forget the lectric bit just pull the the starter clutch/gear out and get your wallet out........oh and new oil and filter.
    And take some piccies.
  1. Starter
    By crp47 in forum Dominator / FMX
    Last Post: 19-09-09, 06:49 PM
  2. XL starter clutch
    By tommywilly in forum XL
    Last Post: 20-05-09, 09:36 PM
  3. For Sale: Dominator nx650
    By BIGROG in forum For Sale / Wanted
    Last Post: 22-02-09, 07:54 PM
  4. Nx650 j k l m
    Last Post: 19-11-08, 05:08 PM
  5. CHAPTER 9 - ALTERNATOR & STARTER CLUTCH
    Last Post: 26-03-06, 05:23 PM
