Honda Trail Bike Forums
Go Back   Honda Trail Bike Forums > Honda Trail Bikes > Dominator / FMX
Reply
  #1 (permalink)
Old 07-02-10, 10:26 AM
Junior Member
SLR 650 oil conundrum
Hi there,
This is probably going to sound like a silly question but I am a bit of noob. I just got a slr 650. On checking the oil the dipstick is reading very low. I would like to top it up but I have 2 questions. 1) What oil do I use? 2) Where do i top it up? Is it through the same hole as the dipstick at the top of the frame between the handle bars?
Thanks.
  #2 (permalink)
Old 07-02-10, 10:33 AM
catteeclan's Avatar
Senior Member
Re: SLR 650 oil conundrum
Yeap, same hole as the dipstick.
As for the oil it depends what is already in there, shouldn't go to far wrong with semi 10/40.
Better still give it an oil change so you know what's in and what to top up with next time as they do use a bit.
__________________
08 TDM900,
96 Dominator,
84 XL600lm,
82 XL500r.
  #3 (permalink)
Old 07-02-10, 03:03 PM
Member
Location: Just outside Rugby on the M1 side near where the big masts used to be.
Don't simply top it up, run the motor first in case it's wet sumped a bit. If you do not have a manual the procedure is to run the motor until warm, allow it to settle for a miniute or so then check the level with the dip stick resting in it's hole not screwed in. Also as the bike has a wet clutch only use motorcycle oil or the clutch might slip. Car oils have friction moderators and are unsuitable. Semi synthetic is best all round. Happy riding.
  #4 (permalink)
Old 07-02-10, 03:39 PM
Mervinh's Avatar
Crab transporter
Quote:
1 Yes it is dry sump the oil tank is the downtube
2 it is wet clutch
merv
__________________
Handle every stressful situation like a dog
I you cannot eat it or hump it
piss on it and walk away
  #5 (permalink)
Old 07-02-10, 08:17 PM
Member
Quote:
2 it is wet clutch
merv
Thought it is a wet clutch, if I'm wrong can someone confirm please because then I can use Castrol Magnatec which is top class oil and available from supermarkets etc.
  #6 (permalink)
Old 07-02-10, 09:50 PM
Mervinh's Avatar
Crab transporter
Confirmed i have changed on in my SLR that i had before and it is running in oil
__________________
  #7 (permalink)
Old 08-02-10, 01:48 PM
Senior Member
Certain oil's can cause clutch slip. so if clutch slips when you have used magnatec you will have to change oils.
I have used 'car oil's' in various bikes and had no problems.
Reply
Tags
650, conundrum, oil, slr
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
speedo conundrum!!! SENSAI Transalp 4 13-09-09 03:28 PM
