Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 50 of 50
Thread: Dommi supermoto
  1. #41
    switch's Avatar
    Feb 2009
    Romania
    Re: Dommi supermoto
    A word of caution to AFK40: that bracket you made mounts on some very BAD bolting points. Those threads in the top clamp are butter-tough and if you even slightly over-torque them, the mounting point will be useless. Be careful there!
    El Vencejo is offline Senior Member
    Dec 2009
    Re: Dommi supermoto
    Ayup John (afk40)
    SLR disc dimensions: 275mm diameter, 140mm internal. PCD = 6(hole) x 165mm (mounting hole to hole across the disc). No offset, flat disc. Clearance between disc and fork stanchion = 7mm.
    All that counts really is the disc diameter and the fork leg clearance, ,which can be adjusted by spacers.
    Just measure your Dommi and let us know if it fits.
  4. #43
    afk40's Avatar
    afk40 is offline Senior Member
    May 2006
    Near Glasgow Scotland
    Re: Dommi supermoto
    Davy. I was out tyhe day wi ma pal on his XT,, so we tried out the speedo... at 30mph its the same on the FMX clocks.. 50mph is also the same at 70mph its 65 on the FMX...... I changed all the wiring from ma original clocks Lume on ma domi, so that the plug would fit into ma harness, as the fmx had a different plug an all the bulb holders wir different as well... but I need tae have a look at it again.. an extend the wires by about 2 feet so that i can again hide all my electrics under ma frame on top of ma head under the tank........ a job fur next week , a wis out fur a guid run the day,, it was warm an sunny. done 120 miles.. all back roads. luved it.......cheers. john
  5. #44
    afk40's Avatar
    May 2006
    Re: Dommi supermoto
    Switch.. I dont know the torque setting fur they bolts.. i only used on o them, as theres 2 top yoke bolts an 2 bottom.. i used one from each bottom yoke to mount lights.. an only one on the left fork top to mount the barcket,, the other side is mounted wi the the bolt that holds the cables.... I wouldnt like to do the threads in on the Yoke... but thanks fur pointing that out. cheewrs......
  6. #45
    Dec 2009
    Re: Dommi supermoto
    Just done some top end work: the torque settings are b*/***, try to wind up the 6mm bolts to the recommended torque and they'll just strip the threads. Seems that you have to work by feel ??
  7. #46
    afk40's Avatar
    May 2006
    Re: Dommi supermoto
    well guys ave changed it yet again......... I fitted a wee headlight cowl tae house ma wiring... although i had hidden all the wiring,, i had to pull it all out again, as i wanted to fit the new clocks so the plug was short on the lume, so it all had to come out again,, an finding a place fur ma cdi was a nightmare.. i found the best place was the left side o the tank. strapped wi a tie strap.... it done me ok fur yesterday tae go tae the bike show,, but needs looked at,, some kind gent could jist see it an take it fur badness,, then ad be trully gazzooka`d............
    yel see in the pics, what I done ,, wi th eblue cowl.. it looked ok but jist wasnt right,, as a had a bunch o wires in there behind the clocks.......
    so last nite,, well at 3.30 in the mornin.. i went out tae ma garage,, tae hae a looky at it again.. i couldnt sleep..... so this is what a come up wi.
    I took the blue cowl off an brought all the wiring into view... to have a good look an try an imagine where it would all go... so a started cutting an trimming.. all i needed was an extension on the Plug on the lume.. so I had to lengthen 8 wires... so that my cdi could go as before underneath ma tank an frame in the pics.. an the wiring lume could all be hidden as well. so I set about to do that.. im now happy wi the outcome.. CDI`s hidden away,, wires are kept tae a minimum... all the rest o the wee boes an switches are hidden on top of th ehead an under the tank frame.... then i set about to fit another Cowl...
    so heres the new cowl... wi minimum wires behind it,, the light works perfect, hig an low beam.. no fancy daft lights,, as a dont plan to be riding at nite anyway.... only if a get caught out somewhere.. an intae the bargain,... i turn into a Mr Hyde after 11pm... sio heres what I done in the pics.. also a fitted a pair o indicators as well .. i think it looks ok.. an this will do it till i get a suitable cowl.........
    enjoy......!!!
  8. #47
    afk40's Avatar
    May 2006
    Re: Dommi supermoto
    Oh aye an a changed ma Exhaust as well,, it too loud, its not really LOUD LOUD, but it frightens the horses an the sheep, an that s too loud fur me.. as when ye pull the odd wheelie,, it attracts attention,, so am gonna have a GPR can up fur grabs... as I fitted ma old sytem... much quieter... pics o ma last blue cowl an ma current white one,, wi jist about no wires behind it........
  9. #48
    afk40's Avatar
    May 2006
    Re: Dommi supermoto
    I cant see a picture of ma Blue cowl,, I do have a few on ma phone which I took yesterday at the top of a big hill down near abington where wqe climbed a hill.. what a view.. a`l see if a kin get it on ma pc then a`l post it........... cheers.
  10. #49
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Re: Dommi supermoto
    Quote Originally Posted by afk40 View Post
    Glad it's all working. Don't know what's going on with them speedos then?
    Haven't had your stuff yet, when did you post it?
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
  11. #50
    afk40's Avatar
    May 2006
    Re: Dommi supermoto
    cattee.. I posted it on Thursday .. it was first class,, it should be with ye the morra,,,,ad ave thought the day... hopefully the morra...
  1. Two up on the Dommi
    By stelladragon in forum Dominator / FMX
    Last Post: 25-03-10, 01:11 AM
  2. Dommi New Boy
    By lobbaslob in forum I'd like to introduce myself....................
    Last Post: 02-02-10, 05:03 PM
  3. Dommi Wiring
    By kenny1950 in forum Dominator / FMX
    Last Post: 17-02-09, 09:31 AM
  4. XBR to Dommi
    By cafe650 in forum Dominator / FMX
    Last Post: 05-09-07, 10:00 PM
  5. Dommi special
    Last Post: 08-07-07, 11:30 AM
