Hello
I bought a 99 Dominator a couple of months back, It's been great until last week when the front brake just stopped working. The lever comes right the way into the bar with no resistance and no braking effect at all. The pads are ok, there is no sign of fluid leaking and the reservoir is full. I bled the system but it didn't fix it so I though that the problem must lie in the master cylinder. I replaced the piston and seals in the the master cylinder (nearly £50 !!! with P&P and VAT) but it still doesn't work. With a full reservoir and the brake pipe removed the fluid should squirt out when the lever is pulled, but nothing happens. I've checked and re-checked that everything is fitted correctly and yet it still doesn't work.
Does anyone have any ideas or had a similar problem in the past ?
James
