Results 1 to 10 of 14
Thread: Dominator - leaking carb
    jcoll is offline Member
    Jul 2010
    london
    Hi all, i just bought a domi for spares repairs and have managed to get good spark. However it doesnt start as the carb is screwed. With the pettock on, the overflow tube from the float bowl pours out fuel. I've taken the carb apart and it was pretty clean, so i cleaned it some more, put it back and the same thing happens. Any ideas?
    Thanks in advance
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Re: Dominator - leaking carb
    Sounds like the float needle is sticking or got a little bit of dirt in it, or the float height is set incorrectly, try tapping the side of the float bowl in case it is just stuck before you strip the carb again
    Jul 2010
    london
    Thanks. It turned out i hadnt closed the drain screw when i put the carb back together again. But the bike still wont start. Its got an imobiliser but if that wasnt working i wouldnt get a spark would i?
    Jul 2010
    london
    zippychips's Avatar
    zippychips is offline Senior Member
    Apr 2010
    swansea
    Quote Originally Posted by jcoll View Post
    is it getting fuel to the chamber ...is the plug getting wet? (but not too wet)
    why did you take the carb apart in the first place ???
    Jul 2010
    london
    The spark plug is dry, the air coming out of the cylinder is a little petroly but obviously not petroly enough. I took the carb apart as it was over flowing and just to see what condition it was in and if anything was blocked or seized.
    zippychips's Avatar
    Apr 2010
    swansea
    is the diaphram in the carb ok ?
    i cant think of anything else that would stop fuel getting to the engine ..
    Jul 2010
    london
    The diaphragm looked fine. Im bidding on a carb on ebay thats about to end so i'll see if that ones any better. Hopefully ill pick it up this afternoon
    sbikerbud is offline Senior Member
    Apr 2007
    birmingham UK
    could it be that it has no compression?
    No suction from cylinder would mean no fuel sucked through carb
    Jul 2010
    london
    Its blowing air out of the spark plug hole when its open and out the exhaust so i guess its got compression. The guy i bought off said he hadnt ridden it for a bit and when he finally did it had trouble starting and wouldnt really pull away. Thanks for your insights everyone, ill get there eventually.
  1. Leaking oil...
    By winxp-master in forum Mechanical Advice
    Last Post: 13-03-10, 09:21 PM
  2. Dominator 89 carb remove and clean with pics
    By RuiNx650 in forum Dominator / FMX
    Last Post: 11-07-09, 03:09 PM
  3. For Sale: dominator carb
    By Mervinh in forum For Sale / Wanted
    Last Post: 22-04-09, 03:02 PM
  4. Dominator NX250 Carb
    By Pinchers in forum Dominator / FMX
    Last Post: 26-03-09, 09:25 AM
  5. Help please she is leaking fuel
    By Lord Vader in forum Mechanical Advice
    Last Post: 01-01-70, 06:19 PM
