Results 1 to 10 of 39
Thread: Where to get nx650 jets
    jj5
    jj5 is offline Member
    Mar 2010
    Netherlands
    I treated my dommie on fresh oil, filters and a new spark plug recently and i found out the bike is running way to lean. (only mod is a k&N filter). Where can i get loose jets. I can only find those way over priced dynojet kits which only seem to contain some jets and a needle
    zippychips's Avatar
    zippychips is offline Senior Member
    Apr 2010
    swansea
    Re: Where to get nx650 jets
    Quote Originally Posted by jj5 View Post
    these are courtesy of Rubberchicken
    this is a list of honda partnumbers, usable at your local honda dealer
    For completeness sake, a list of jets and their part nrs.
    #JET | Old part nr | New part nr
    #150 | 99101-393-1500 | 99101-GHB-1500
    #152 | 99101-393-1520 | 99101-GHB-1520
    #155 | 99101-393-1550 | 99101-443-1550
    #158 | 99101-393-1580 | 99101-HN2-1580
    #160 | 99101-393-1600 | ?
    #162 | 99101-393-1620 | 99101-GHB-1620
    #165 | 99101-393-1650 | 99101-GHB-1650
    #168 | 99101-393-1680 | 99101-MFC-1680
    once again thank you to Mr Chicken
    jj5
    Mar 2010
    Netherlands
    great think im gonne cut the carburetor loose today and see whats in there and order some bigger jets. Can you just replace the main jet or does the rest of the carb also needs some fiddling?
    Rubberchicken's Avatar
    Amsterdam
    Everything is influenced by everything.
    Here's a handy guide: CV Carb Tuning Procedures
    You basically start out with the main jet. Get that right, then work your way down past the needle height, the idle mixture, and the float height.
    It's a fiddly time consuming job...
    My advice would be to splash out and stick it on a Dyno some time, to get a reliable measurement. Looking at spark plug colour hasn't been the same since they went with unleaded petrol, they're all grey now even if the bike is running rich.
    What bike are we talking about anyway?
    Michel
    '89 NX650 -- R.I.P. -- Gone
    jj5
    Mar 2010
    Netherlands
    A 1988 Dominator
    Amsterdam
    Right, nearly the same as mine then.
    And bone stock except for the K&N which doesn't change much as the intake restriction is in the snorkel.
    Mine ran pretty well out of the box with the stock (US-spec) #155 and #48 jets. Bit on the thin side, but not ridiculously so. The idle could do with one size bigger (#50) to take care of the idle stalling problem, and depending on how much it's done I'd replace the needle tube as well, as they tend to wear oval.
    Which jets does yours have?
    I've found ordering jets pretty easy at CMSNL. As in at least they had them. I went to a local Motoport first for a #160 jet, and I guess it's still on order as I haven't heard since. Only ordered it in 2004...
    Michel
    jasonbc's Avatar
    Camborne, Cornwall
    Quote Originally Posted by zippychips View Post
    www.oro2u.com
    offroad only sell the jets and needles for most bikes individually, if they are not listed on their site give them a ring they shouldn't have any problems getting them
    GASGAS TXT250 PRO 2006
    jj5
    Mar 2010
    Netherlands
    how fast do they deliver? i need em this week
    Dunno what jets i have had to stop yesterday cos i had other appointments so only got the plastics and tank of. Will go and have a look at the carburetor in a sec.
    It doesnt stall much. It does stall sometimes mostly when the engine is hot but its not a regular thing.
    Amsterdam
    Hmm this week is going to be... Ambitious.
    I haven't ordered from them recently, but they can take about a week or so.
    Do you know which jets you need or are you still experimenting with the setup?
    Michel
    jj5
    Mar 2010
    Netherlands
    right now im at the stage where you wanne set the bike on fire. I cant get the carburettor out
    Any tips how to get the carburettor out? I followed the steps from the service manual. but that things is just stuck there there is just no room XD to get it even lose from the airbox.
  1. e bay jets
    Last Post: 06-09-09, 06:17 AM
  2. main jets
    By seedy in forum XR
    Last Post: 25-02-09, 11:42 PM
  3. Carburetor Jets
    Last Post: 26-12-07, 11:51 AM
  4. Jets
    By DaveS in forum XR
    Last Post: 22-06-07, 10:02 PM
  5. Jets to use with a K&N airfilter?
    By samih in forum Africa Twin
    Last Post: 17-06-04, 10:41 PM
