thinking of changing my headlamp for a supermoto look what do you do with the speedo and indicators does any one have any pictures or advice how to do it please
Here's a pic of my SM, indicators are mounted on little metal brackets that go through the fork leg clamp bolts on the top yoke, speedo is similar but using the handlebar clamp bolts which go through the top yoke as mounts. Most folks swap standard speedo for a Trailtech Vapor or similar digital affair.
HTH
If you can fabricate a metal bracket, you can bount the clocks to the handlebar directly. A friend fixed a bent piece of steel ~4mm thick in between the handlebar mounts and top triple clamp and mounted the clocks onto that plate. It was a pretty bad setup IMO since he had trouble reaching the ignition.
thinking about fitting the super ailien headlight it has indicators in it so that solves the problem what to do with them just need to find out what to do with the speedo now will get a better idea when headlight comes
