Results 1 to 9 of 9
Thread: another Dominator in the forum
    gonzalo75 is offline Junior Member
    Feb 2010
    Barcelona, Spain
    Hello,
    I am new to this forum and just wanted to say hi before I start asking questions…
    I bought a ´96 Dominator back in February. At first I found it quite daunting because I was coming from a 49cc moped. Only now I am starting to relax a bit. I am still struggling sometimes with the downshifts, which can be a bit “abrupt” if I don´t open the throttle in the right moment, but getting there.
    The bike had 38.000km on the odometer when I bought it and it is now approaching the 45.000km mark. During this time the bike has been performing great. Actually I the only work I have done on it so far is replacing the oil and oil filter.
    The only problem I have is that it stalls every now and then in traffic lights. After reading some threads in this forum I know now that the problem is quite common. Soon I will open the carburettor to replace the idle jet, hopefully fixing the issue. But that will be in a few weeks time, when it is not so hot outside.
    For now I leave you with 2 photos of the bike, one on its own and another with a friend.
    gonzalo
    Windmill John's Avatar
    Oct 2008
    Re: another Dominator in the forum
    Before pulling the carb off, let's get the two most commons things out of the way first.
    Dominator, SLR, Vigor, Transalp, they all must not have their tickover too low.
    Make sure it is at least 1100 rpm
    Make sure your choke is not stuck.
    Can't remember from my Dommie whether you could sort that out without removing the carb.
    Great bike, but the hardest carb in the world to remove
    I found it easier removing a bank of four carbs of a 750!
    Honda Transalp XL650
    BMW R65
    First Honda CB200 in 1978
    Biggest Honda CB750F2 in 1981
    Lots in between
    paulc's Avatar
    paulc is offline Senior Member
    Nov 2009
    Carshalton,London, United Kingdom
    Quote Originally Posted by Windmill John View Post
    Agree ,turn up the tick over just a little bit and see if it helps
    SiNX650's Avatar
    SiNX650 is offline Member
    Feb 2010
    Cumbria
    Welcome Gonzalo.
    Great pics .
    Just got a bigger idle jet to solve the problem on mine, not yet fitted though.
    zippychips's Avatar
    zippychips is offline Senior Member
    Apr 2010
    swansea
    Welcome Gonzalo!
    what a nice reason for not working on your bike ... wish i could say the same ...here in the uk its "ill change the jet when it stop raining"
    jeez i need a job in spain lol
    jj5
    jj5 is offline Member
    Mar 2010
    Netherlands
    I have set mine to idle at 1400-1500rpm it never stalls
    switch's Avatar
    Feb 2009
    Romania
    If not properly warmed up (dead cold engine), the bike is likely to stall at lights unless you keep the throttle SLIGHTLY open. [oil temp >60'C should be fine]
    If the spark plug is old, the bike might stall at idle. [spark plugs should be replaced along with oil filter = every other oil change-- they're dirt cheap anyway]
    If the idle is below 1400, the bike might stall. [manual recommends 1350rpm+-100rpm; I get best results with 1400 since it allows a free clock-less idle soon after starting; check idle at normal op. temp.]
    Other causes might include gummed up carb, bad card settings (bad mixture) and aging problems (rubber intake manifold cracked).
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Why change the idle jet? Just turn the mixture screw out 1/4 to 1/2 turn.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    Feb 2010
    Barcelona, Spain
    Thanks for your answers.
    The first thing I did when I bought the bike was increasing the idle speed to 1500rpm. This is easily done with a little black knob on the side of the bike.
    This improved things a bit but I still have the problem, even when up to running temp.
    I will follow the rest of your recommendations and I will let you know how it goes.
    Regards
    gonzalo
  1. New to this Forum
    By GARY J in forum I'd like to introduce myself....................
    Last Post: 28-02-09, 07:55 PM
  2. new to the forum
    By silverbiker in forum Transalp
    Last Post: 06-02-08, 08:38 AM
  3. Thanks again to the forum
    By Meat in forum Africa Twin
    Last Post: 20-04-06, 10:50 PM
  4. Best forum
    By jabba in forum Chatter
    Last Post: 01-02-05, 09:22 PM
