Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: RD02 Oil Temp Gauge
    SiNX650's Avatar
    SiNX650 is offline Member
    Feb 2010
    Cumbria
    RD02 Oil Temp Gauge
    What are the options for checking the oil temp on an '89 Dominator?.
    Have found temp gauge dipsticks that replace the original one, but they are only for '95-on models.
    Thanks .
    jj5
    jj5 is offline Member
    Mar 2010
    Netherlands
    Re: RD02 Oil Temp Gauge
    The only option i know of is indeed the dipstick.
    On ebay there are a few i think. Dont think there is a diffrence between the 95 and 88-94 sticks btw.
    Rubberchicken's Avatar
    Amsterdam
    Yes there is a difference!
    The ones that go in the RD02 are a lot bigger (diameter) than the RD08.
    Gericke used to have them both, might want to check there.
    Michel
    '89 NX650 -- R.I.P. -- Gone
    SiNX650's Avatar
    Feb 2010
    Cumbria
    Thanks for the replies.
    I'll check at HG.
    raymo's Avatar
    aberdeenshire Scotland
    how about a Trailtech Vapour, I have one that got a temperature sensor on a copper ring that goes under the spark plug to measure cylinder head temperature, guess you could make a dip tube and slot the sensor in there?
    you would also have a speed rpm and trip counter too
    and the temperature reading would be on the dash and not at the oil filler
    XRV 650R RD03 1989
    The Longest Day Rider 6
    jj5
    Mar 2010
    Netherlands
    wait you can fit a trailtech vapour on the dominator?
    Amsterdam
    Quote Originally Posted by raymo View Post
    Not that that matters a whole lot on the dommie, the oil filler being directly in front of the petrol tank.
    Michel
    raymo's Avatar
    Home - Trail Tech Products Limited
    oil in Frame like the RD01, but filler near the head stock ahhhh
    even better shoeter wires
    you can fit a trailtech to anything may up grade to the stiker as it also give volts!!!!
    Ray
    XRV 650R RD03 1989
    jj5
    Mar 2010
    Netherlands
    How do you get a RPM reading then? it needs some kind of adapter that fits the dommi cabel.
    My speedo died so would be great replacement for me :P
    raymo's Avatar
    rpm is simple, ( a thin wire wraps around the HT lead 5 times to act as a pick up )
    speed is a small black sensor thingie with a magnet on the disc ( they supply a replacement bolt and a few other options to mount the magnet )
    temp
    water cooled :- its a short jumper pipe to insert in the hose line
    Air cooled:- its a copper ring that goes under the plug and so give Cylinder head temperature
    had one on the XLV for about 3 years now.. temp is for rear pot..
    defo saved me doing some serious mischief when the rear carb pilot jet blocked and it was running real lean and the temp shot to 200+
    Ray
    XRV 650R RD03 1989
  1. temp gauge not working?
    By fairbrother1969 in forum Africa Twin
    Last Post: 23-07-09, 10:19 AM
  2. Temp Gauge - Part 2
    By brownetara in forum Transalp
    Last Post: 21-05-09, 01:48 PM
  3. Temp gauge u/s ?
    By pete h in forum Varadero
    Last Post: 21-04-08, 11:10 PM
  4. Temp Gauge
    Last Post: 17-08-06, 01:03 PM
  5. temp gauge
    By Gav in forum Africa Twin
    Last Post: 07-12-05, 08:00 AM
