Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: dominator supermoto makeover
    redun's Avatar
    redun is offline Member
    Jul 2008
    Lincoln
    Well I have had my dommie for about 2 years now and I have used this forum to gain a great amount of info about the dommie so I thought I would show you my dominator so far......
    This is how it looked when I bought it:
    Well after a while of riding it I soon grew tired of the awful 90's pink graphics so I removed them and spayed over the offending area.
    I then wanted more power in the right palaces so I bought a set of front pipes from ABP in Germany to go with the single Arrow can that was on the bike when I bought it. This freed up the midrange and made the back lanes a real treat. I then tinkered with the carb as per the FMX tunning thread and this gave better gains top end. The only thing left was a bit more grip from the tyres.
    It was about this time I saw a few supermoto dommies in France and Germany and thought "hmmmm that looks like the answer!"
    And so below is the result of my dominator supermoto make over:
    The makeover consists of:
    ABP Racing header pipes
    Clamp on foam filter and tinkered with carb
    Renthal bars, risers and lever guards.
    CBR 600 front wheel, brakes, mud guard and lower fork stanchions.
    VFR single swinger, wheel and brakes with CBR 600 rear shocker.
    Custom battery bracket.
    OEM rear end removed and replaced with custom lights under rear guard, custom number plate bracket and luggage rack removed.
    OEM pillion foot pegs removed.
    All plastics and tank sprayed in gloss black.
    Clear front indicators and LED bulbs installed through out.
    Wheels powder coated white.
    Custom made "Jack Daniel's Racing" graphics.
    Plus there is still lots of little bits I want to do to it that people don't normally notice but they will add to the bike overall.
    But then again nobody's bike is ever finished is it..............................
    Warthog's Avatar
    Mar 2007
    Re: dominator supermoto makeover
    Nice set-up. I had a Dommie SM, too. Great fun!!
    If you want grip, you want a nice set of BT 090s....mmmmmm!!
    So where do the upper fork sliders come from? They look like they give the bike a lot of travel!!
    Baltic Safehouse, 10 mins from the Tallinn ferry terminal.
    1993 TA600, Wheels (front and back), Brakes (50% warped), Engine, Seat, some lights, Smelly and noisy tube at the back, other assorted metal bits, dubious sense of direction.
    2007 Ural 2WD, Wheels (front and back and side), Brakes, Relic (Engine), Seats from farmyard machinery, lots of lights, Smelly and noisy tubes at the back that catch everything, other assorted home made metal bits, insatiable rust and petrol addiction.
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    That VFR swinger looks the dogs b+++++ks.
    Good work.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    ploch is offline Member
    Feb 2010
    argyll scotland
    loving this bike the swing arm looks good keep up the good work
    gpzDave's Avatar
    gpzDave is offline Now on a BMW R1100RS.
    Aug 2010
    Fife, Scotland
    Hi Redun,
    That's an awesome job you've done there! The VFR swingarm looks great, really unique.
    Lam's Avatar
    Lam
    Lam is offline Senior Member
    Jul 2007
    Kerry Ireland
    thats a grand job there
    redun's Avatar
    Jul 2008
    Lincoln
    cheers for the nice messages
    Warthog, the fork uppers are the OEM dommie ones so i could get the height I needed because of the front wheel being 17" and the rear 18". At the moment i am running the bike in and letting it all settle in and so far the forks feel really good. I might change the springs in the forks at a later date if they do turn out to be a bit soft.
    Warthog's Avatar
    Mar 2007
    As I said, I SM'ed my Dommie, but nowhere near as comprehensively: mine was "SM-light".
    I kept all the original suspension and only re-spoked the original hubs to 17" rims.
    This made the final set-up a bit more straightforward: I only needed to adjust the headlight aim, get a speedo converter, and shave some metal from the fork brace...
    switch's Avatar
    Feb 2009
    Romania
    More details on the VFR swingarm conversion?
    redun's Avatar
    Jul 2008
    Lincoln
    warthog, One of the tricks i used on my bike could be used on your bike too.
    My front wheel was a 17" from a CBR 600 and i used the speedo drive from that as it had the correct ratio for the 17" wheel. I then used the CBR speedo cable and a 6" universal extension to give the cable a bit more play when turning. Best of all it used the OEM dommie clocks
    switch, The swing arm is from a VFR 400 nc30 which i had to machine the width to make it fit between the dommie frame and then fabricate the shocker mount to mount the CBR shocker directly to the swing arm.
    unfortunately its not a simple swing arm swap
  1. My Dominator supermoto
    By Gixergav in forum Dominator / FMX
    Last Post: 06-01-12, 10:39 PM
  2. RD03 All the gear makeover
    By Traveller in forum Chatter
    Last Post: 25-09-09, 09:59 PM
  3. Dakar makeover
    By boboneleg in forum Other Bikes
    Last Post: 05-05-08, 09:09 AM
  4. Supermoto Dominator
    By Lutin in forum Dominator / FMX
    Last Post: 09-02-08, 10:21 PM
  5. Preparing for next winter 'makeover'
    Last Post: 25-08-06, 01:27 PM
