Results 1 to 3 of 3
Thread: Front wheel noise FX650 Vigor 2000
    picasso is offline Junior Member
    Sep 2010
    uk
    Hi / Have a 2000 FX650 Vigor with 11,000 mls am getting a strange noise from front wheel . Had new brake pads fitted recently / does not appear to be the pads / piston or speedo / the sound is best described as a soft whistling noise / does not appear to be the pads rubbing against the disc could it be front wheel bearings ? Steering head bearings also needing replaced . Anyone else experienced similar problems ? \on the steering bearings are you better going for the geniune honda replacements or are others OK. Quite a difference in price. Appreciate any thoughts .
    switch's Avatar
    Feb 2009
    Romania
    Re: Front wheel noise FX650 Vigor 2000
    Quote Originally Posted by picasso View Post
    Pads rubbing against the disk is my bet. If you didn't clean the brake pistons, it's a likely culprit.
    Still, bearings can easily be checked by just removing the wheel. No biggie.
    I heard that there's a replacement for the OEM steering bearing that's both slightly cheaper and better in terms of function.
    Sep 2010
    uk
    Thanks Switch / I will look at getting the piston / caliper stripped down to see if it helps Picasso
  1. FX650 Vigor bakes
    By MKNoble in forum Dominator / FMX
    Last Post: 29-07-09, 10:45 AM
  2. FX650 Vigor
    By IgorVigor in forum Dominator / FMX
    Last Post: 14-06-09, 08:21 PM
  3. Replies: 7
    Last Post: 10-04-09, 10:24 PM
  4. Front Brake probs - Vigor fx650
    By somebigfella in forum Dominator / FMX
    Last Post: 27-09-08, 09:05 PM
  5. New exhaust for FX650 Vigor
    By kawasami in forum Dominator / FMX
    Last Post: 02-06-08, 11:46 AM
