Dommie cuts out at low revs - Need help!
Results 1 to 10 of 16
Thread: Dommie cuts out at low revs - Need help!
    Lourdite is offline Junior Member
    Aug 2011
    UK
    Guys I need a bit of help. I have owned an 1988 NX650 for 1 year now and it hasn’t ever run properly and I am out of ideas. I welcome any suggestions you can offer. The bike starts properly when the choke is open full and the revs are high, as soon as I start to close off the choke the bike runs rough then starts to pop as if there is a build up of fuel, the pops become closer together then it stalls.
    So far I have swapped the coil, carb, CDI, it has had a new camshaft and rocker arms, tested wiring loom for continuity, bypassed ignition, swapped stator. I have not been using the tank, I have been supplying fuel from a funnel and hose so it’s not a fuel supply problem, new plugs, air filter, HT lead, new battery.
    Any ideas, so far I have an expensive paperweight!!
    Rubberchicken's Avatar
    Amsterdam
    Re: Dommie cuts out at low revs - Need help!
    Sounds like the mixture is somehow off. Does it rev ok, or is it messy all over the rev range?
    Is it stock or has it got a different exhaust and/or air box mods and such? (A ratty old leaking stock exhaust may cause trouble too.)
    Cleaned the carb? Which size jets were in there? Blocked slow jet perhaps, that'll mess up the low revs.
    Check the underside of the rubber thing between cylinder head and carb, that has a tendency to split on the older dommies.
    (The one on the left is new, the one on the right has a bunch of hair cracks.)
    Michel -- '92 R100GS PD -- Our Lady of Blessed Acceleration, don't fail me now!
    kitped's Avatar
    kitped is offline Senior Member
    Jul 2007
    Cambs
    There is a thread somewhere about the exhaust valves being an issue, the can cause stalling at low revs, I think but may be wrong that the exhaust valves gap should be greater than the books says. I can't do a search at the monet but wil try and look later.
    2002 RD07a Black & all the bits
    1989 RD03 Current project....
    1999 CR250 Great fun when I get time...
    1976 CB500T Cafe Racer Work In Progress
    Cozmo1589's Avatar
    Cozmo1589 is offline Junior Member
    Feb 2012
    Poole UK
    I had a similar problem and even when the carb was overhauled the bike still did the stall on occasion. I was told to try the premium high octane fuel and a iridium spark plug. Have never looked back, the bike runs great now
    Aug 2011
    UK
    Sorry forgot to mention, I have replaced this pipe, mine did have a small split in it.
    Aug 2011
    UK
    Kitped,
    Thanks for the advice, I'll have a look for a thread on exhaust valve clearances. In the meantime if you know what the gap you have used is I would be grateful if you could let me know.
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Inlet .10mm /.004in
    Exhaust .12mm /.005in
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    Amsterdam
    The trick with the right hand exhaust port is that it has the automatic valve lifter. Setting it at exactly TDC would cause weirdness, IIRC that one needs to be set just a bit past or before TDC.
    But I get the feeling that there's 2 different "cutting out" things going on:
    1. There's the legendary Dominator Stall, especially at or approaching traffic lights with closed throttle. Bike will otherwise idle well, just cuts out every now and then. This is normal.
    2. Running rough at low revs is an indication that something more is amiss.
    1. can be fixed by turning up the idle speed a bit or by carefully adjusting the idle mixture (that impossible vertical air screw on the underside) and/or fitting a slightly larger slow jet if necessary. Decent spark plug will help, too.
    Aug 2011
    UK
    Thanks mate, I will have a look at these, if I could only get the bike to run at low revs I would be happy, when I turn the choke down it is dead in less that 120 secs!
    Amsterdam
    Yeah that would be a case of number 2...
    What's the minimum revs (roughly) at which it does keep running?
  1. Dommie Cutting Out at High Revs
    By ianrg in forum Dominator / FMX
    Last Post: 02-10-11, 09:52 PM
  2. Dommie Cutting Out At High Revs
    Last Post: 01-08-11, 05:11 PM
  3. xr250 cuts out when hot??
    By xr250 baja in forum Mechanical Advice
    Last Post: 12-01-11, 09:57 PM
  4. 250 cuts out
    By eddclarke in forum XR
    Last Post: 05-10-09, 07:13 PM
  5. Dommie cuts out?!
    By jodasdommie in forum Dominator / FMX
    Last Post: 19-08-09, 01:17 PM
