rounded off nut
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: rounded off nut
    buddy71 is offline Junior Member
    Jan 2009
    munster, southern ireland.
    rounded off nut
    Hey again lads, I went to change the oil on my dommie and discovered the oil drain bolt next to the gear lever is rounded off, I,ve tried getting a thin nosed
    vise grip but theres no room to manouvre it to even budge the bolt!
    Im wondering what are my options, I just want to drain the oil and was in the process of doing this, the oil drain bolt on the frame came out no problem so I have a good bit of the old oil already emptied out, is there anything else I could undo to drain the rest of the oil?
    Rubberchicken's Avatar
    Amsterdam
    Re: rounded off nut
    I was facing this on my old NX but never got around to it.
    Laying the bike on its side with a pan under the open crankshaft plug will get most of the oil out but it's far from ideal obviously (and potentially quite messy).
    Possible fixes I've theorised about include getting the engine out, or at least loosened enough to be able to rock it and get some working space. These will work but it's a lot of work and the pipes need to come off which are fragile. Another option might be to get a dremel in there and turn the unruly bolt into something that'll take a flat blade (impact driven) screwdriver, or get someone to weld on an extension bar from a socket set...
    Michel -- '92 R100GS PD -- Our Lady of Blessed Acceleration, don't fail me now!
    hotbulb's Avatar
    May 2009
    Cardiff
    Re: rounded off nut
    The oil in most boat engines is sucked out by syringe or pump....... don't know if this would be possible with the Dommie engine, but perhaps it could get you out of a fix??
    XR Mad's Avatar
    XR Mad is offline Senior Member
    South wales
    Re: rounded off nut
    I've used a different version of these before and was amazed how well they worked had to tap the socket on wth a hammer to get it to bite in but once it bit the bolt was out
    DAMAGED NUT AND BOLT REMOVER - MADE IN THE USA! XSB100M | eBay
    AlanH's Avatar
    Bristol, UK
    Re: rounded off nut
    If it is not completely rounded off, a metrinch or 6 wall drive socket may still budge it. I am amazed at the state of some of the nuts I've shifted with mine.
    KTM 990 Adventure
    Jakey is offline Senior Member
    Nov 2011
    Bedfordshire
    These sometimes work;
    http://www.irwin.co.uk/cdetail.php?c...51&Cat=&crumb=
    Or drill the bolt and use an 'easy out'
    Jan 2009
    Re: rounded off nut
    Thanks for all the answers lads, the damaged nut and bolt remover seems to be
    my best course of action, Il let ye know how it goes
    Re: rounded off nut
    I agree with a previous poster. Try a six sided socket rather than a 12 point bi-hex, had this work on a totally mullered bolt head before now.
    1 Varadero/34,000 miles ridden (of 57,000 miles on the bike), it's all still new to me!
    XR Mad's Avatar
    South wales
    Re: rounded off nut
    Quote Originally Posted by Jakey View Post
    Product Details
    Thats the ones i've used. if you can get them to bite they pull themselves onto the head of the bolt the harder you turn them the tighter they grip
    jasonbc's Avatar
    Camborne, Cornwall
    Re: rounded off nut
    Quote Originally Posted by buddy71 View Post
    try hammering a smaller imperial socket over it and see if it will undo or drill it and put an easy out down there.
    GASGAS EC300 2006
  1. Rounded Screw
    By Savak in forum Transalp
    Last Post: 29-12-10, 04:04 PM
  2. Another rounded screw
    By beddowsm in forum Africa Twin
    Last Post: 22-09-10, 10:13 AM
  3. More rounded nuts.....
    By doglegdon in forum Mechanical Advice
    Last Post: 02-06-07, 09:54 AM
  4. Fairing nut rounded off
    By BuckarooBanzai in forum Mechanical Advice
    Last Post: 30-05-07, 01:55 PM
  5. Rounded off bolt head - help!
    By Gav in forum Africa Twin
    Last Post: 03-02-06, 12:05 PM
