MIX Screw Seized and Broken
Results 1 to 4 of 4
Thread: MIX Screw Seized and Broken
    mogz is offline Member
    May 2009
    south west wales
    Discovered my Mix srew is goosed rest of the carb is in good nick and very clean I have been playing aound with the jets but stuck if cant adjust the Mix, Was thinking of just going for a Flatslide Curent set up is Now...
    Single Arrow Can (Baffle In)
    Headers Standard
    KandN Filter with standard air box
    175 Main Jet
    Needle Lifted by about 0.5mm
    Still not running brilliant definatly smoother than stock but still have tick over problems when warm
    and the plug shows still running a little lean.
    Have thought of getting hold of stock parts and returing back to factory set up ????
    nick in brum is offline Senior Member
    Dec 2010
    birmingham
    Re: MIX Screw Seized and Broken
    Quote Originally Posted by mogz View Post
    have heard the fcr40 or 41 off a 450 mx bike ,such as a crf works very well,
    quite a few posts on it over on thumpertalk,
    thought about putting one on my flattrack style special
    Blackboilersuit is offline Junior Member
    Mar 2012
    Scotland
    Just stripped down a completely knackered set of carbs from an old XJ600 with a mate of mine. Despite nearly all the idle jets and mix screws being chewed up and seized we managed to get them all out. Pouring a kettle full of boiling water onto the screw before trying to turn it can work wonders. If the slot is all chewed up then using an engraver with a long sharp point can open out the slot a bit (even if the screw is buried in an alloy housing) to get some purchase with a screwdriver. If you get a screw moving a little bit then be patient and work it back and forth with some WD40 before going for another kettle of boiling water. If its moving and it starts to go tight then go for more boiling water rather than forcing it.
    Worth a try rather than scrap an otherwise good carb.
    Best of luck
    Stewart
    May 2009
    south west wales
    Quote Originally Posted by Blackboilersuit View Post
    Best of luck
    Stewart
    Guess this is worth ago.. The bike is definatly running lean will get the kettle on
  1. Pilot screw broken off
    By angelo in forum Africa Twin
    Last Post: 04-06-11, 04:00 PM
  2. Seized brakes
    By beddowsm in forum Africa Twin
    Last Post: 31-12-10, 11:06 AM
  3. Seized Transalp
    By Neil67 in forum Transalp
    Last Post: 02-09-10, 09:38 PM
  4. Carb pilot screw seized
    By quaycrest in forum Africa Twin
    Last Post: 01-01-09, 11:15 PM
  5. seized!
    By Shayite in forum Transalp
    Last Post: 08-06-08, 08:26 PM
