Dommi cutting out
Results 1 to 8 of 8
Thread: Dommi cutting out
    Chippy310 is offline Junior Member
    Feb 2012
    Wales
    Dommi cutting out
    Hi
    Hello to all!
    Just got myself a dommi had the problem with tickover upped pilot jet now sorted!
    Now when it's ticking over its fine when handlebars are straight but when you turn them left or right
    The idle slows down an it's cuts out?
    I took the throttle cable off totally and it makes no difference!
    Bounder is offline Senior Member
    Feb 2011
    West Cork, Ireland
    Re: Dommi cutting out
    Check the choke cable as well.
    Feb 2012
    Wales
    Done it was choke cable! Cheers
    Idle sorted, changed pilot jet from 48 to 50 and ever sinse iv done that
    If you hold it wide open in top gear it sputters an it's very hesitant about 3000rpm
    Iv taken the snorkel off an it seems a bit better but not right!
    Rubberchicken's Avatar
    Amsterdam
    Pilot jet 48 or 50 will have no influence on any wide open throttle whatsoever, really. That will be a different problem...
    Michel -- '92 R100GS PD -- Our Lady of Blessed Acceleration, don't fail me now!
    Feb 2012
    Wales
    Thanks for the help guys!
    It's now got a different problem, when riding along it cuts out it seems to be losing spark an iv noticed the rev clock drops down to zero.
    When this happens if I flick the kill switch on and off it cuts back in, but it does the same thing if I wiggle the wires going into the cdi?
    Feb 2011
    West Cork, Ireland
    Check the plug is seating properly.
    If the plug is OK and the wires aren't cracked internally then the CDI unit could be breaking down.
    When does the bad running manifest itself, when hot?
    The CDI units will break down, best to buy a new one from ignitech.cz they are around 110 euro IIRC.
    Worth checking the killswitch as well, make sure its not worn inside.
    daleynewman is offline Junior Member
    Apr 2012
    Velserbroek, Holland
    Quote Originally Posted by Chippy310 View Post
    I had the stuttering problem around 300rpm too. Turned out that the outer choke cable was too long...... (Maybe from the previous owner???) The choke needle couldn't return into carb fully. After shortening the outer cable; problem solved. Did the Dave's carb mod recently too. This made my Dommie run much smoother all round. Good luck.
    XR Mad's Avatar
    XR Mad is offline Senior Member
    South wales
    Quote Originally Posted by daleynewman View Post
    I thought i was the only one with that problem i done the same to my choke cable. when i first bought the bike it was using excessive amounts of fuel and this fixed it
    Where in wales are you chippy
  1. Two up on the Dommi
    By stelladragon in forum Dominator / FMX
    Last Post: 25-03-10, 12:11 AM
  2. Dommi New Boy
    By lobbaslob in forum I'd like to introduce myself....................
    Last Post: 02-02-10, 04:03 PM
  3. Dommi upgrade
    By chamber66 in forum Dominator / FMX
    Last Post: 13-04-08, 11:30 AM
  4. Dommi/FMX Forks
    By kenny1950 in forum Dominator / FMX
    Last Post: 28-03-08, 01:17 PM
  5. XBR to Dommi
    By cafe650 in forum Dominator / FMX
    Last Post: 05-09-07, 09:00 PM
