Results 1 to 10 of 10
Thread: Servicing a 950/990
    Ashley M's Avatar
    Ashley M is offline Senior Member
    Apr 2007
    Buckinghamshire
    Servicing a 950/990
    I am very interested in a KTM 950 or 990 but I’ve heard there a bit of a nightmare
    To service 3 hours to change the oil, is that right also my friend has the 660 (I think that’s right) he has only done about 30,000 miles or so and he needs a top end rebuild he has always has it serviced by a dealer, is the 990 the same.
    nomad's Avatar
    nomad is offline chicken chaser
    horwich, bolton, lancs
    Re: Servicing a 950/990
    Quote Originally Posted by Ashley M View Post
    three hours to change the oil ! my arse
    sounds expensive to do a top end rebuild after 30 k if it's true ?
    my 950 had only done 15 k so i can't really answer your question
    if someone on here has covered that sort of mileage i'm sure you'll get your answer soon ?
    have you looked on adventure rider ?
    Ashley M's Avatar
    Apr 2007
    Buckinghamshire
    If I’m wrong about 3 hours to change the oil & filter how long does it take, I can do it on my @ In less the half an hour, I was told you had to take all the fairing off? I should have said oil and filter change
    stanbloke's Avatar
    stanbloke is offline Happy Bunny!
    Jul 2007
    Milton Keynes by the Sea
    Try this link, it will show you how to diy.
    http://www.ktm950.info/
    Palmer's Avatar
    Palmer is offline Senior Member
    Oxfordshire
    Im not sure it's going to take 3 hours, but you havn't got any access to the enguin with the fairing on so i should think you have to take the tank etc off, remember singles take more abuse so the the 30k may be true
    Chad's Avatar
    wickford,essex
    Quote Originally Posted by stanbloke View Post
    WHAT A FECKIN ACE SITE MATE
    stanbloke's Avatar
    Jul 2007
    Quote Originally Posted by Chad View Post
    jasonbc's Avatar
    Camborne, Cornwall
    these guys may be able to help a little further
    http://www.ktmforum.co.uk/
    Ashley M's Avatar
    Apr 2007
    Buckinghamshire
    Sadly it looks like a right pain to change the oil and filter and you have to clean some mesh screens as well, (tank of to this) I love the bike but want to spent my time riding it not taking it apart, so I think I will stay with my @ less power but a lot less hassle.
    Thanks for the info everybody.
    (from a nearly a KTM owner)
    mouse is offline Junior Member
    Apr 2008
    Birkenhead
    It's not too bad to do the oil on an LC8 once you get the knack of it. But it is a bigger job than on a lot of other bikes, that's true.
    Changing the oil filter is simple, you just remove the cover from the left hand side of the engine, no fairing removal required, although you have to drop the bash plate.
    To clean the oil pickup screen on the right hand side is equally simple.
    There's a screen in the oil tank output but to be honest I usually don't bother with that, on the few occasions I have pulled it out it's been clean anyway. These are only coarse mesh screens so unless you've got some serious **** in your engine they'll not need cleaning.
    To drain the oil you can remove the left hand fairing and tank to easy access to the drain plug. Some people have said you can drain it without removing the tank, using some sort of funnel / pipe arrangement I guess.
    I reckon I can change the oil on mine in about an hour. But doing the same on my wife's Fazer would only take 20 mins
    I'm sure if you took the bike to a KTM dealer they'd charge for 3 hours labour!
  1. 8k Servicing Cost
    By pete07bikes in forum Varadero
    Last Post: 02-05-07, 07:34 PM
  2. Servicing
    By Biggy in forum Transalp
    Last Post: 20-03-07, 11:52 AM
  3. transalp servicing
    By fred600 in forum Transalp
    Last Post: 23-03-06, 10:35 AM
  4. Servicing
    Last Post: 18-03-06, 11:24 AM
  5. Servicing items
    Last Post: 21-02-06, 06:31 PM
