Results 1 to 10 of 13
Thread: Clutch like an on/off switch
    Dogfart Guest
    Hi,
    The clutch on my 05 adventure 950 is like an on/off switch, there is hardly anything from fully in to fully out but it doesn’t seem to be dragging. Only had the bike two weeks and its been like that since I got it so I was just wondering if everyone else is the same. If not what can I do about it, I have fiddled with the knob at the lever but all that does is move the biting point in and out.
    Dogfart.
    stanbloke's Avatar
    stanbloke is offline Happy Bunny!
    Jul 2007
    Milton Keynes by the Sea
    Re: Clutch like an on/off switch
    Might have a couple of plates stuck together.
    Have you tried bleeding it (make sure you use the correct fluid tho).
    Might be an idea to get the seals checked in the slave. (down by your left toe). .
    Dogfart Guest
    I'll get some stuff and try bleeding it, I take it from your reply this is not normal operation for these bikes, EG the clutch should be smoother. My clutch has literally 2 or 3 mm between the biting point and fully out
    Dogfart
    stanbloke's Avatar
    Jul 2007
    Quote Originally Posted by Dogfart View Post
    Dogfart
    2/3mm bite or 2/3mm from the bar .
    These are sharp clutches anyway ( not far off a race bike quality really) the whole bike is pretty aggressive compared to the more user freindly Jap bikes.
    if this is 2/3mm "Bite" sounds ok to me. Its not a Honda . .
    Dogfart Guest
    its 2 to 3mm bite, I can live with it, I just wondered if it was normal. Just means it takes a bit more concentration to slip the clutch at slow speeds like crawling up to lights or in traffic. I still love this bike its just so much fun. Its everything other adventure bikes would like to be.
    Dogfart
    macrider's Avatar
    macrider is offline Junior Member
    Apr 2008
    Reading
    hey dogfart,after i had all this hassle with my clutch,i found a few of them (clutch plates)were fractured so replaced the lot,£155 quid!!!! ouch,i had sheared bolt on clutch booster,boo,so tried to remove the centre nut,which was to much for me to do,so off to bike shop,they had to strip it down and use a heat torch to release the nut,and found a seal behind had gone so that got replaced about £1.20,i have now put it all back together again,and she is running like a dream again,so maybe that little seal has gone on yours????
    Dogfart Guest
    nice to know macrider, im just going to live with it for now. From what i can gather its pretty normal, I have full movement of the lever its just that the bite point is about 2mm from the bar and the fully engaged point is about 2mm further from the bar. Just makes for the odd amateure looking start out of junctions now and then.
    outrunner's Avatar
    outrunner is offline Grumpy auld man!
    Sep 2008
    Selkirk, Scotland
    Nothing new there then.
    Andy.
    Scottish Safe Hoose!
    Red BMW F650gs twin...........the wee wolfcub!
    stanbloke's Avatar
    Jul 2007
    Adjust your lever till the "Bitepoint" is 10/15mm from the bar. should be a bit more comfortable. .
    Dogfart Guest
    Quote Originally Posted by outrunner View Post
    Andy.
    Aaa but it means wheelies should be easyer
  1. Hazard switch add-on
    By bandi in forum Africa Twin
    Last Post: 12-11-06, 07:25 PM
  2. switch on coil
    Last Post: 30-08-06, 06:42 PM
  3. handlebar switch
    By Whealie in forum Chatter
    Last Post: 09-06-06, 08:54 AM
  4. cut out switch
    Last Post: 11-04-06, 03:19 PM
  5. Neutral switch
    Last Post: 07-03-06, 10:27 AM
