Results 1 to 10 of 20
Thread: Instrument panel not working.
    Dogfart Guest
    2005 950 Adventure
    Hi, just started the bike up to check the battery and the instrument panel is not working. Everything else seems fine, bike starts and runs fine the headlights and tail lights work fine. Its just everything on the dash. No lights no digital readout and no rev counter.
    Any help in where to look for the problem most welcome.
    Best regards and a Merry Christmas to all
    Dogfart
    nomad's Avatar
    nomad is offline chicken chaser
    horwich, bolton, lancs
    Re: Instrument panel not working.
    have you checked the connectors at the back of the clock ?
    stanbloke's Avatar
    stanbloke is offline Happy Bunny!
    Jul 2007
    Milton Keynes by the Sea
    Fuse in the glove box.
    Dogfart Guest
    Most likely a fuse, is the fuse for the instruments in the glove box? There is a bit of a story attached, I found that the batter was going flat every week or so while its been sitting in the garage. I traced this, just by chance to the heated grips being wired directly to the battery. By removing the fuse for the heated grips the batter now holds its charge but I now have this new problem. I replaced the heated grips fuse just to check but still no instruments.
    Too much eating and drinking to be done today, will have a look at it tomorrow and report back what the problem is.
    Dogfart
    doglegdon's Avatar
    Southern Philippines
    Sorry mate, no help offered here, as heated grips aren't S.O.E. in the tropics, but I go with Stan, check all fuses in the tank boxey.
    If not that, then try the old AT remedy, disconnect the battery for as few minutes, reconnect, then try to on the ignition again?
    (I know it'll be a pain to undo the underneath protection, but........?maybe?)
    Good luck!
    2008 KTM 990 Adventure S
    Dogfart Guest
    Its worse than I first thought, I have no indicators, brake light or instruments. The trouble shooting guide in the manual says
    "Replace fuse HORN BRAKELIGHT SPEEDO" but I have checked this and it seems fine, I replaced it anyway. The bike has not moved since it was last working and I have started it up as recent as last weekend at which point everything was fine.
    Starting to get depressed
    Dogfart
    stanbloke's Avatar
    Jul 2007
    Quote Originally Posted by Dogfart View Post
    Dogfart
    Try disconnecting the connectors and spraying them inside with WD40, I had a mate with a Fireblade that would'nt start, took the r/h control apart cleaned it and gave it a squirt....... ChaChing!! .
    I kow it sounds simple but sometimes moisture can be the cause. .
    Dogfart Guest
    have now had the bike to bits and disconnected and reconnected everything I can find but still nothing. checked the power to the 10amp fuse that the manual points me to and there is no power to that connection at all.
    any help please
    allan
    SPG's Avatar
    SPG
    SPG is offline Senior Member
    Sep 2008
    Hitchin Herts England
    Hi , i know that this link started a while back BUT i have just had the same thing happen to my 950 Adv , did the same as you and could'nt find the fault until i looked at the large connector at the top of the frame behind the fuse box a wire had come out !!!! seems to have corroded and then fell to bits so stripped it out managed to get the metal connector out of the plastic connector soldered it up put it back and on came the clocks!!
    I hope yours is as simple to find and fix??
    SPG
    Dogfart Guest
    Quote Originally Posted by SPG View Post
    SPG
    thanks SPG I have not looked at that yet, I have been going on advice that it must be a bad earth but have not found the fault yet. I will have a look at that one on the weekend and get back to you.
    was your fault the same, EG clocks, indicators and brake lights?
    Dogfart
  1. XR125 instrument panel
    By Mekon88 in forum XR
    Last Post: 06-09-08, 03:23 PM
  2. Holes in my panel
    By LEOPARD in forum Africa Twin
    Last Post: 25-08-08, 08:18 AM
  3. WTB RDO4 instrument cluster
    By lear60man in forum For Sale / Wanted
    Last Post: 04-06-08, 02:44 PM
  4. rh rear panel
    Last Post: 30-10-07, 04:20 PM
  5. XRV 750 INSTRUMENT BULBS
    By fw750x in forum Africa Twin
    Last Post: 10-12-06, 09:52 PM
