Not sure if this is just me, but I have a real problem seeing the oil level on my dip stick on my 950, so I was thinking of spraying it mat black so when the oil is on the dip stick it should look shiny, what do you think.
why not just rough up the dipstick with a bit of wet and dry?
It is already. The oil is pretty new, it will probably be easier to see when it gets dirty but that’s not much help at the moment.
I vote for spraying it white!![]()
2008 KTM 990 Adventure S
Get some bifocals !!.
You are just in denial about being "Past it" Ash!..
Use a lollypop stick
IT IS BETTER TO TRAVEL ONE MILE THAN TO READ A THOUSAND BOOKS (CONFUSIUS 500 BC/ISH)AND A BIG UP TO IBN BATTUTA
ADVERTISE HERE.
Absynth eye dropssee things in a new way
You sure there's oil in it?
Well I’ve sprayed it mat black and it is easier to see but not the contrast I had hoped for, I guess I’ll have to change that 30watt bulb in the garage after all
