Results 1 to 5 of 5
Thread: Fork seal weeping oil......
    doglegdon's Avatar
    Southern Philippines
    My right front fork seal has started to weep a little oil, I was wondering whether it's because the average day time temp here is getting pretty hot (35-43 deg C). I have opened both the pressure equalisation screws on the steering head then retightened them, to see if that will stop the leak. However, have also taken the liberty of ordering new seals, since I have it under warranty still. Anyone experience the same problem and apply that remedy, did it work?
    2008 KTM 990 Adventure S
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: Fork seal weeping oil......
    Yes and no then a yes and yes
    my seals went just before the TT last year I tried the pressure and checked the levels as it was only a light smearing, (I had just done a bike awareness day with loads of emergency breaking) but had to change the seals but in there favour I dont know how old they were
    2 weeks ago at the MOT the tester said your fork seals are leaking, Bugger not again but I ignored it for the week and was going to sort them out now they are dry again,
    I do keep saying I will fit gaiters another on a long list of todo's
    doglegdon's Avatar
    Thanks SH, the loosening of the pressure release screws seems to have worked, no more leaks/weeping. Have ordered new seals and oil anyway as they'll be free.
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Oh, we like free
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Quote Originally Posted by Snaphappy View Post
    kitchen paper under the dust seals just before you go helps
    merv
  1. fork seal tool
    By starfazer in forum Dominator / FMX
    Last Post: 14-03-09, 09:19 PM
  2. Seal gone awol..
    By fatowl in forum Transalp
    Last Post: 16-08-08, 03:26 PM
  3. Fork seal replacement
    By harper in forum Mechanical Advice
    Last Post: 25-07-08, 06:22 PM
  4. RH Crankcase Oil Seal
    By BuckarooBanzai in forum Transalp
    Last Post: 15-03-08, 10:46 AM
  5. leaking piston seal
    Last Post: 06-06-05, 09:20 PM
