Results 1 to 4 of 4
Thread: Fork seals and new oil have i done right?
    Ashley M's Avatar
    Ashley M is offline Senior Member
    Apr 2007
    Buckinghamshire
    I’ve just had a go at changing my fork seals which I think is a success
    (have to go for a ride on it to be sure) but I’m not sure if I’ve put the oil in
    Right, (yes I know I should have asked the question before starting the job)
    I found some good demos on You tube which helped but when it came to
    The oil my internals didn’t match any I could see, so what I have done is
    Just pour 700mm into the forks and put the caps on and then pushed them
    Up and down a few times then put then back on the bike, is it that simple
    Or am I missing something out.
    The bike is a 950s 2003 adventure
    Stormforce8's Avatar
    Dec 2005
    New Forest - Hampshire-on-Sea
    Re: Fork seals and new oil have i done right?
    According to the main dealer that I spoke to about this (Sideways KTM), and bearing in mind that this would be for a 2003 KTM 950 Adventure - not the S.
    • Remove top fork cap
    • Remove spring
    • Fully compress Fork all the way down
    • Fill with 5W oil until you have a 100mm air gap from the top.
    • Drop the spring back in
    • Screw the fork cap back on
    • Re-assemble fork
    Repeat with the other fork.
    Now I know that the S is slightly different so you might want to check the air measurement gap with your local dealer.
    And I can heartily recommend air bleeders if you want to stop blowing oil through the fork seals.
    Stormforce8 SmugMug gallery
    Rugged Roads
    Current stable.............
    Ashley M's Avatar
    Apr 2007
    Buckinghamshire
    Thanks for that, thats not have i did it i knew just pouring in the oil was to simple, i have taken mine out for a ride today and i must say they are much better now then before i did them, i have air bleeders on mine already. Thanks for the information and when I have to redo them at least I now know how to next time. ( I have been told that the oil will fill up all the right places in the forks but I will just have to bleed a lot more air out of them first, so i think I'll leave then for now and see how i get on
    Thanks again for the info
    stanbloke's Avatar
    stanbloke is offline Happy Bunny!
    Jul 2007
    Milton Keynes by the Sea
    Fork Leg R&R
    Use this link Ashley There is a right way to install the forks after removing them from the yokes.
    Hope it helps.
  1. The fun of fork seals
    By scudmotodude in forum Dominator / FMX
    Last Post: 05-07-09, 07:06 PM
  2. Blown fork seals.
    By Pieeyedpiper in forum XR
    Last Post: 13-06-09, 07:54 AM
  3. Dominator fork seals
    By Simon WS in forum Dominator / FMX
    Last Post: 11-08-08, 07:26 AM
  4. what fork springs or fork mods?
    Last Post: 05-04-05, 08:13 PM
  5. Fork seals
    Last Post: 20-12-04, 08:20 AM
