Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Help 950 has no power
    boboneleg's Avatar
    Bristol
    Re: Help 950 has no power
    Quote Originally Posted by Ashley M View Post
    The story so far, it turns out its not running weak as I first suspected, the reason the exhausts are so white is the at the rear spark plug is not firing which means the un-burnt fuel is going into the end cans then burning off which is the cause of the look of the exhausts, I changed the plug it run for a while then the plug was all fouled up, cleaned it and it did the same thing, long story into a short one, engine out rear cylinder off and found a small piece of metal in there but I can not find any damage to anything and nothing obvious as to were the metal has come from , apart from this the piston, barrel and head look in very good condition the bikes done 35,000 miles and has a full service history
    Thanks for all the ideas I'll let you all know if i find the cause
    It's not a piece that's dropped off the plug is it?
    2003 Transalp
    2004 KTM 950 ADV
    1998 Suzuki DR350
    Ashley M's Avatar
    Ashley M is offline Senior Member
    Apr 2007
    Buckinghamshire
    I don't think so the plug looks ok and it was still working before i took the engine out
  1. More power and better mpg...
    By Aubrey in forum Transalp
    Last Post: 26-05-09, 04:54 PM
  2. power for sat nav ect
    By RickSkye in forum Transalp
    Last Post: 18-03-09, 10:04 PM
  3. Help no power
    By 1211jeff in forum Africa Twin
    Last Post: 30-09-07, 06:53 PM
  4. Sat Nav Power.
    By Cabby in forum Transalp
    Last Post: 19-08-07, 09:27 PM
  5. No power
    By 5135jimmy in forum Africa Twin
    Last Post: 14-12-06, 09:54 AM
