This was how i bought her and i am very pleased with her
I got fed up with people asking me what i wanted for xmas so told them to club together and get me a new plastics and graphics kit for the bike.
First job though wa to mod the sidestand mounting bracket as the stand flies up so far and visiously it's broken the botton of the old plastic panel off.
I drilled and tapped a 4mm hole through the bracket. Screwed a nyloc onto a 4mm bolt and screwed the bolt up through the bracket then put a nyloc ontop to stop it unwinding.
result is now the stand sits clear of the plastics.
and the finished result is................................................ ............
Wonder how long it will stay looking like this for.............The only other thing i did was to extend the wiring loom to the rear lighting unit and cut short the cable on the lighting unit. Only reason for this was it was a pain in the asss having to take the side panel and seat off each time i wanted to remove lights as the connector was in the air box, it's now on the sub-frame
