I reckon if you've used the ADV for your previous trips, then take the opportunity to try the Africa Twin - I think you might be pleasantly suprised.
I don't care what anyone says - you can't compare the bikes as they are two totally different machines - but they are both VERY capable.
I'd love to hear your thoughts after using the Twin - have followed a lot of your ride reports over on GSer forum.
Make sure you have crashbars - and either carry a spare fuel pump or swap it out for a Facet - nothng else to cause any problems.........
The seat is admittedly not the best around - but there are lots of ways of improving it - having it sculpted, change the foam, airhawk, dead sheep.....but then again you might find it perfectly acceptable as standard.
Fuel range - most Twins are capable of at least 200 miles - depends how you are on the throttle - can be as low as 170 - or as high as 250 - so unless you're going somewhere 'really' remote this shouldn't cause an issue (anyhoo you could always siphon some out of your travelling companions BMW if needed
For me the Africa Twin is a great bike - doesn't really excel at any one thing, but as a package it's brilliant
Please keep us updated - I'd love to see the ride report .
