Results 1 to 10 of 16
Thread: Engine Difference Hot or Cold
    Roy_W Guest
    I have noticed that in the morning when the air is still cold and I start the the bike, during the 10km run to work the engine runs incredibly smooth. It quite literally purrrrrrsssss. It's as if there is perfect harmony between the Air temperature, humidity and engine temperature etc..., I love it it.
    [The temperature gauge is barely above the lowest mark at this point ]
    In the afternoon when returning from work the engine makes a lot more noise, probably valves, timing chains or whatever and loses that lovely purring feeling.
    [The temperature gauge is usually about 1/4 the way above the lowest mark at this point, which is usually its nomal position when warm and running ]
    Question : Why does it purr when cold and then become clunky, chinky, metallic when warm. What would I have to do, check, tinker with, in order to retrieve that lovely purring in the afternoon when the air is warmer ?
    PS : The bike runs great regardless of morning or evening.
    Simon Guest
    you are travelling in a different direction and therefore the wind is going a different way. Would that be the reason?
    Roy_W Guest
    Quote Originally Posted by Simon
    I could verify that idea if only I could find the bloody reverse gear, where do they hide it ?
    faantjie's Avatar
    faantjie is offline Lost Lost Lost
    May 2006
    Happy Valley, Surrey
    I don't know why but have noticed the same thing on the Alp.
    captaincaveman's Avatar
    captaincaveman is offline Senior Member
    Jun 2006
    Northamptonshire
    ive noticed it on every vehicle ive had(bike or car) always seens to run better in cold, is it cause the air is denser and therefore more air per bang? and therefore more power? also is the smoothness down to the fact that everythings tight before the heat makes all the metal expand a bit?
    Chad's Avatar
    wickford,essex
    oils cooler as well so it thicker i suppose its a little bit of all these things
    faantjie's Avatar
    May 2006
    If only I could be so smooth in the mornings
    Dilbert's Avatar
    Apr 2005
    Staffordshire Moorlands
    Yes, the motor does work better in the morning because of the cooler air (up to a point) and the way it combusts and pretty soon Jenna or someone will be along to give us a dissertation on exactly why
    The other thing I find is that at 6:30 am there is a lot less traffic to hold you up than at 6:30 pm so you can go at your own pace and everything just feels smoother and nicer.
    djadams's Avatar
    Mar 2006
    Sussex
    More power cos of cold air, smoother and quieter cos of cold (thick) oil.
    Most powerful when air cold (dense), coolant cold (so charge doesn't get warmed up too much) and oil up to temperature (so thin and slippy).
    Quietest and "smoothest" when oil cold (so thick and gloopy), air temp not really relevant, except that it has an effect on oil temp and coolant temps, obviously.
    Last of trio is:
    Most economical when air warm (reduced pumping losses), oil warm (thin, slippy), coolant hot (so not much heat robbed to coolant).
    GeoBloke's Avatar
    GeoBloke is offline Senior Member
    Oct 2005
    Stroud, Gloucestershire
    Quote Originally Posted by djadams
    Last of trio is:
    Now that the mornings are cooler, I've been wondering why the @ is more "up for it" those first few miles. I put it down to the denser air yielding a bigger bang. Duh. I don't think your brain is as small as your avatar lets on, professor. Get on the wiki with a course on internal combustion physics. I'll sign up!
  1. doesn't like the cold - she does now!
    Last Post: 21-02-07, 06:44 PM
  2. 2 wheels with a difference
    By Cie in forum Other Bikes
    Last Post: 21-08-06, 03:28 PM
  3. What a difference a day makes
    By anton88 in forum Ride Reports and Pictures
    Last Post: 16-07-06, 10:24 PM
  4. 650 Model Difference
    By wheeliebin in forum Transalp
    Last Post: 04-01-06, 10:07 AM
  5. carb difference
    By peter blackshaw in forum Africa Twin
    Last Post: 28-06-05, 05:08 PM
