Results 1 to 8 of 8
Thread: Led Valve caps
    barryw33's Avatar
    barryw33 is offline All the gear...no idea
    Sep 2006
    Malaga, Spain
    Led Valve caps
    does anyone know the law with regards to led valve caps. with winter approaching and the dark mornings on the way, i am looking for a way of making myself more visible to the communters. Have seen the led valve caps on ebay but just wanted to know if i am risking a pull from our friends in blue
    captaincaveman's Avatar
    captaincaveman is offline Senior Member
    Jun 2006
    Northamptonshire
    Re: Led Valve caps
    Quote Originally Posted by barryw33
    there bloody dangerous, i had ones that changed colour on my buell and i spent more time leaning off the bike looking at them than i did looking at the road
    Not sure on the law i had em on for over a year and forgot id got em and i never got pulled, so not sure
    fw750x's Avatar
    fw750x is offline xrv750x Pilot
    Belfast , Northern Ireland
    Hi Barry Just a word of warning , using these led valve caps puts strain on the valve stem where it joins the tube. I read this on a couple of different motorbike forums do not fit them .fw750x
    Sometimes when i think the world,s all bad , Then i see some people on Motorcycles it makes me take another look. Steve Mcqueen.
    Richie B's Avatar
    Richie B is offline Senior Member
    Jul 2005
    Salisbury, Wiltshire, United Kingdom
    As a car driver, as i'm sure you probably are too, nothing beats a big, fat flourescent luminous overcoat over your normal weatherproof kit to see a motorcyclist.
    Streetcred perhaps out the window, but worth it my opinion.
    Now the night are drawing in I always chuck one one.
    2003 KTM 640 Adventure
    2011 AJS JSM 125 Trail (Salisbury Plain Toy)
    matt Guest
    LED valves
    I have one on the front. The force on the valve is nothing. The centripetal force is far far far less than the air pressure in the tyre. Or look at it another way, you think of the punishment these wheels are designed to take!
    I have no idea if it works because I don't lean down to have a look!
    Another option of the hi-vis rim tape, which I have thought about, but I would start to look a bit granddad at this rate....
    Ralphie's Avatar
    Ralphie is offline Bovvered? Look at my face
    Mar 2005
    Dublin, Ireland
    Wear these
    I suspect if you want to be seen at night and not want to be pinched for the Led valve caps, try wearing these as well
    http://cgi.ebay.co.uk/BOOBIE-FLASHIN...QQcmdZViewItem
    cheers
    Ralphie
    Richie B's Avatar
    Jul 2005
    Gotta get me some of those....!
    matthelliwell Guest
    Re: Led Valve caps
    ISTR that flashing is illegal and there is limitations on the colours but I can't remember the details, though I think it's less restrictive on bikes than cars. Start reading here and get very bored: http://www.opsi.gov.uk/si/si2005/20052559.htm
    I've got a set of them but I'm not convinced that they are particularly visible so I stuck some retroreflective tape on my bike instead.
  1. Valve clearances
    Last Post: 18-06-11, 09:23 PM
  2. which valve is which?
    By kiroh in forum Africa Twin
    Last Post: 17-11-06, 06:22 PM
  3. VALVE CLEARANCE
    Last Post: 26-04-06, 08:38 PM
  4. Valve cover
    Last Post: 27-09-05, 06:30 AM
  5. Led Valve caps
    By The Specialist in forum Africa Twin
    Last Post: 01-01-70, 05:48 PM
