Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Chain adjustment and the Haynes manual
    billy is offline Senior Member
    Jun 2006
    Bristol, South West
    Thanks Darkenbad, Dilbert and Austin for your help and time!
    Billy
    djadams's Avatar
    Mar 2006
    Sussex
    Just to be clear, both suggestions here are right. There's a difference between the "slack" as described by Honda and Haynes, and the clearance checked by a go/nogo stick.
    The first refers to the distance you can move the lower chain run if you pull it down til it's tight and then push it up til it's tight, at roughly the half way point of the run - so 40mm or so from lowest position to highest position.
    The gauge checks the clearance between the chain and swingarm when the chain is pulled tight downwards - so 70mm between chain and swingarm.
    And again, without wanting to sound like a cracked record, the correct slack does not depend on rider weight/luggage load, it depends on suspension geometry. (The point being that the chain should always have some slack regardless of the position of the rear swing-arm, regardless of whether the bike sits in the tightest position the whole time (heavily laden) or only reaches it over large bumps (lightly laden) - at no point do you want to stress the wheel/gearbox bearings, either way).
  1. haynes manual
    Last Post: 24-10-06, 09:35 PM
  2. Haynes manual for 04 model
    By alpslapper in forum Transalp
    Last Post: 07-10-06, 02:32 PM
  3. Chain Adjustment!!??!!
    By ZZR 2 Transalp in forum Transalp
    Last Post: 20-06-06, 07:04 PM
  4. Haynes Manual
    By SydneyAT in forum Africa Twin
    Last Post: 01-01-70, 12:51 PM
