Results 1 to 10 of 12
Thread: Chain adjustment and the Haynes manual
    billy is offline Senior Member
    Jun 2006
    Bristol, South West
    Hello Folks,
    Recently adjusted my chain to setting list in the Haynes manual ( 35-45mm on the side stand), but it seems too tight to me ! Have they got it right ?
    Billy
    P.S. TA 91
    squirrelciv Guest
    Don't know what bike you've got matey, but I'd say thats OK. Give the wheel a spin and re-check it. Sometimes bikes get a tight spot and you don't want it tightening up on you.
    Jun 2006
    Bristol, South West
    Thanks squirrelciv for help and time
    Dilbert's Avatar
    Apr 2005
    Staffordshire Moorlands
    Billy do a search on this site, this is a FAQ for these bikes, but sounds like your guessing right, the chain should be loose even on the sidestand, how loose depends on the model you've got, there's an article in the ATIC site to that should help
    http://www.atic.org/faq/chain.html
    Jun 2006
    Bristol, South West
    Thanks Dilbert for your help and time
    Billy
    Darkenbad is offline Senior Member
    wales
    If its an AT the slack in the chain should be at least 70 mm measured just in front of the rear tyre. Make GO NOGO gauge; lump of wood will do, when it slots in without falling out, slacks about right.
    PK
    Dilbert's Avatar
    Apr 2005
    Quote Originally Posted by Darkenbad
    PK
    To be more specific if it's an RD07/ 07A than do the above, if it's an RD03/ 04 go for the pushing the chain up till it only just touches the chain slider base, as in the ATIC article
    Austin's Avatar
    GARSTANG
    whats one of them then???
    Dilbert's Avatar
    Apr 2005
    Technically it's a precision ground instrument for measuring holes or gaps, in this case it's a 70mm long stick or piece of tubing, if the gap is bigger than 70mm the stick will GO through it, if it's smaller it will NO GO, and if the porridge is just the right temperature then goldilocks has correctly tensioned her bike chain
    wales
    Apologies, should have been abit more specific; as Dilbert has correctly pointed out the info is for the RD07 - the GO NOGO gauge saves time and effort and is a simple enough to make.
    Not sure about the porridge.
    PK
  1. haynes manual
    Last Post: 24-10-06, 09:35 PM
  2. Haynes manual for 04 model
    By alpslapper in forum Transalp
    Last Post: 07-10-06, 02:32 PM
  3. Chain Adjustment!!??!!
    By ZZR 2 Transalp in forum Transalp
    Last Post: 20-06-06, 07:04 PM
  4. Haynes Manual
    By SydneyAT in forum Africa Twin
    Last Post: 01-01-70, 12:51 PM
