Results 1 to 4 of 4
Thread: Loobman chain oiler
    jpc
    jpc is offline Member
    ireland
    Loobman chain oiler
    Any one out there bought or used one of these systems?. They seem to be the bizz.Like to get some feedback before I buy.
    Maverick's Avatar
    May 2004
    Tilbury, Essex
    Lootch67 got one on his AT and seems to work ok, was a bit messy but generally this is what oilers do. Best is to pm him and get some feedback
    lootch67's Avatar
    South Ockendon, Essex
    Keeping the "injectors" in place is a bit of a mission. The main problem though is that you have to keep it clean as there's nothing forcing the oil through - just gravity. I had problems with my Scottoilers "injectors" too, so all in I'd still recommend the Loobman. I haven't been using my Loobman lately as the "injectors" as buggered. Since my daily commute is only 45 miles I tend to pop the bike on the centrestand and oil the chain manually every third day. Works just as well, apart from when you're riding on a very wet road when you can end up with a dry chain. The sad reality is it would seem that none of the two systems are exactly maintenace free, and what maintenance there is is always a dirty business.
    Buck McDancer is offline Junior Member
    Sep 2006
    Sunny Sheffield
    Been using "loobmen" for about 5 years now on various bikes. They're great for what they cost, but as has been mentioned the oil delivery system onto the sprocket isn't a success...it wobbles about & eventually the chain or sprocket will chew it up.
    Instead I use a football inflator needle, positioned above the lower run of the chain. Fits nicely on the end of the tube and slows the oil flow down to a steady drip rate...
  1. Replies: 6
    Last Post: 09-02-07, 01:51 PM
  2. Scott oiler question
    By Xander in forum Mechanical Advice
    Last Post: 08-09-06, 02:07 PM
  3. Scott Oiler Tubing
    By willb in forum Africa Twin
    Last Post: 06-02-06, 05:50 PM
  4. Non Working Scott Oiler
    By Maverick in forum Africa Twin
    Last Post: 12-05-05, 01:32 AM
  5. Chain(again)
    By mal in forum Africa Twin
    Last Post: 17-03-05, 09:51 AM
