Any tips for stripping the decals off the bodywork?
I've got some spare panels I want to try this on so I can think about respraying them. Is there a recommended solvent or is just a case of having to sand it down? If so, anyone got a sandblaster?
I've heard people say heating them up with a hairdryer sometimes works, and I'm sure someone said WD40 is good at dissolving glues...probably best to try those 2 methods separatley!![]()
hair drier gets the decals off but leaves the glue. WD40 does not seem to have much impact.
Angle Grinder then![]()
Hairdryer or heat gun to get decals off. Then brake cleaner to remove the glue.
How do I know? Just done a plastic petrol tank on a XR250.
Worked a treat.
Bill![]()
brake cleaner? That would be new to me, even for cleaning brakes. I shall give it a try though.
petrol is ok. sanding is a waste of time, the glue just clogs the paper.
hairdryer and cellulose thinners is what we use for vinyl stickers, if they're lacquered over then it’s a sand first job to break up the lacquer.
Oh and don’t use the thinners and hairdryer at the same time..boom!
I think you can hammer them out, but you might need quite a bit of filler afterwards.
When I had to do this heat didn't work very well, the blow torch did work a bit but it set fire to the paint as well.![]()
Forum help and advice needed?
2010 KTM 450 EXC-R
Follow xrv.org.uk on Twitter.
Or paper over them! They're selling woodchip, 59p a roll, at B&Q. :idea:Originally Posted by DaveS
Jim
'95 R1100GS
'80 XT250
