Results 1 to 8 of 8
Thread: big bore update 2
    sno335 is offline Junior Member
    Apr 2006
    northampton
    Red face big bore update 2
    Hi, thanks for the wake up call,Dave. Lost 2 passwords and hibernated.
    Attemping to put bored out XRV 750 in Bros. After drawing blank with African Queens ,found out U.S. Hawk GT bigbore (82mm) kit fits.
    C.R. is about 11;1. Downside is only small capacity increase 760cc
    Also spigot and pistons need to be machined to miss longer stroke crank.
    Problems of detonation and the need for high octanes also experienced.
    So started to put top end together with std pistons/bores. However got heads flowed and 2mm larger inlets by Hordpower in Ohio.As the leading expert in the U.S. tuning Hawks J.D Hord reckons this makes the 3 valve engines go.As well as being a seriously successful racer he's a really nice guy to deal with.(Check out the Hordpower website-loads of goodies)
    DaveS's Avatar
    DaveS is online now Ex XRV Site Owner
    Nov 2003
    Bristol, UK.
    Re: big bore update 2
    Quote Originally Posted by sno335 View Post
    See there's no getting away now!!
    Pics and more detail required on the project. Keep us up to date I'm sure there's loads of people interested.
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    anton88's Avatar
    Yep, as Dave S says - get some pics up and more info if you can pleeeeeese - very intersted to know how you get on
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    I fitted a set of wiseco 82mm hawk pistons to my AT, great power increase, a real big boost to the midrange but did have some detonation problems. Biggest drama was the ****ty wiseco pistons, the recomended bore clearances were 2.5 times the standard honda clearances so after 50,000km it was using so much oil i went back to my standard spare engine. there is a place in germany that sells 2mm OS high comp pistons for the AT, also cams and various other bits. It's tuning by Mende.
    http://www.powered-by-mende.de/
    Ive also got a 2 brothers set of OS inlet valves for the hawk but they are the same size as the standard 750 valves, they'd probably be good for a 650 AT or TA.
    did you look into fitting any of the hot hawk cams to the AT ???
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    Another AT - big bore tuning shop
    http://www.stf.at/
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    Hi,
    I was wondering how your big valve heads are going ??. Im considering getting the same thing done.
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    Hordpower http://hordpower.com/index.php?main_page=index is the top hawk 650 tuner in the states, many of the hawk hot up bits will fit the At eg, cams, big valves etc, send him an email he is very helpfull, ive been discussing this with him a bit lately. he thinks 10hp extra (15% extra approx) would not be hard to get reliabily with a good power spread, they are getting almost 90hp out of a full race hawk, however not cheap aprrox $US1200 for ported heads with 2mm OS inlet valves, mild cams, pod filters, mildly raised compression from skimmed heads and a jet kit, thats not including post to send him your heads and return post
    http://www.stf.at/ , do big bore kits and cams for the At, this is the stuff Africa Queens sells
    http://www.powered-by-mende.de/ also does tuning for AT's including bigbore and cams
    http://www.thiel-motoren.de/ also does AT hot up gear
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    Quote Originally Posted by atgreg View Post
    Hi,
    bump bump, any more info on how your engine is ????
  1. handlebar update
    By redmarcus999 in forum Varadero
    Last Post: 22-06-06, 09:54 PM
  2. Mythical Big bore kit
    By sno335 in forum Africa Twin
    Last Post: 20-04-06, 10:09 PM
  3. Frankendom update
    By anton88 in forum Dominator / FMX
    Last Post: 20-04-06, 09:51 PM
  4. Big bore update
    Last Post: 13-04-06, 09:15 PM
  5. Update
    By DaveS in forum Chatter
    Last Post: 07-12-05, 06:22 PM
