Re: Chain link joiners
When I rivet my chains, the first thing I do is to make sure the pressfit plate only goes on as far as the plates on the rest of the chain. I rivet with the link on the rear sprocket at 3 O'clock, when viewed from the sidestand side.Take your time and keep checking from the rear end of the bike to see the plates above and below so you know when to stop pressing the plate.
Same with the riveting. If you use the pro motion tool you can screw the riveter in very slightly a bit at a time. I take mine off the rivet and check it a lot of times even if it takes longer. Better to do it slowly and correctly than have to start again with a new rivet link or worse ride with a defective joint. You're only flaring the hollowed end out enough to stop the side plate moving outward, not crushing a bike thief's testicles.
