Results 1 to 7 of 7
Thread: Optimate on battery while on the run?
    vertigo_blues is offline Junior Member
    Feb 2007
    Singapore
    Just got bought a optimate of Ebay for US$58 inclusive of shipping. Just a question.... Can i connect optimate on battery permanently even when its on the move?? As in riding.....
    Mabels Old Man's Avatar
    May 2006
    The Dark Side
    Re: Optimate on battery while on the run?
    You can leave the Optimate lead on the battery, which is what I think you meant. However if you want to connect the Optimate permanently, which I don't think is want you want you 'd need a bloody long extension lead
    1995 Fireblade Urban Tiger
    2009 BMW R1200GSA
    Events Manager GS Club
    Dee Duble Yuh's Avatar
    South Wales, UK
    It would probably be better to install a charging socket (either a "lighter socket" or a special Optimate one) so you can connect and disconnect it quickly and easily.
    DW (Dave)
    "Let's ride motorcycles!"
    May 2006
    The Dark Side
    Quote Originally Posted by Dee Duble Yuh View Post
    Agreed, however my lead is direct to the battery, with an inline fuse, and I don't think there's much difference to be honest.
    2009 BMW R1200GSA
    Feb 2007
    Singapore
    Quote Originally Posted by Mabel's Old Man View Post
    Hmm... i guess i can leave it on with the lead connected to the battery...but does the optimizer do its stuff even if its not charging? Like optimizing the battery and stuff like that.....
    RainMan's Avatar
    Nov 2006
    Cork, Ireland
    The optimizer will keep the battery at it's optimal rate of charge, hence the name, this will in turn keep your battery at peak performance and extend it's life. What it won't do is over charge your battery no matter how long you leave it plugged in. I think the idea suggested of installing a charging socket is an excellent one. I installed a cigarette lighter socket on my bike and wired the corresponding plug onto the optimizer, both were dirt cheap and now I simply plug the bike in overnight in the garage, without the fuss of trying to clip crocodile clips onto terminals, which also means removing the right hand side panel on my bike.
    South Wales, UK
    Quote Originally Posted by vertigo_blues View Post
    Umm, I believe it does while it's plugged into the mains power, but not when you're "on the run"!
    DW (Dave)
  1. XRV Battery
    Last Post: 07-02-07, 11:29 AM
  2. battery probs
    By tuggy in forum Africa Twin
    Last Post: 15-01-07, 12:45 PM
  3. Battery
    Last Post: 21-09-06, 12:56 PM
  4. Choice of battery
    By Richard in forum Africa Twin
    Last Post: 23-08-05, 09:14 PM
  5. Battery for the new boy
    By matti in forum Africa Twin
    Last Post: 21-02-05, 09:12 AM
