Having been well impressed with Austin's auxiliary lights , as they lit up my rear view mirrors at the recent Scottish borders meet , I decide to fit a set to the Alp. However I have a problem .........
I fitted a set of Ring Micro cruise lights 2 x 55w and wired them in with the ring wiring kit. I followed the instructions to the letter ..... almost.
Power from battery ...... through a fuse and optional switch..... to the relay ..... from the relay to the lights and the trigger circuit from the "position" light ( the small 5w light inside the headlight that remains on regardless of hi-lo beam).
My auxiliary lights are not working.
I changed the relay and switch and tried it without the switch.
All my earths seem OK ( showing 12v between battery +ve and earth screw )
I suspect that the 5 watt position light circuit is not sufficient to trip the relay ????? and it really needed the 55 watts from the headlight circuit, would I be correct in assuming this ?
I don't want to go hacking the connections out if this is not the problem.
Any advice out there ? ........... THANKS !!
