Hey,
I have a problem with the instillation of some new led indicators. They wired in fine, and work as long as I had 3 in and on filament (incandescent) one in. When I put the 4th on in they no longer work. It is not that they flash too fast they do not flash at all.. I assumed that the flasher relay is just getting way too much voltage, so am considering putting a 150ohms /10 watt resistor but this would have to go in line with each indicator. The only problem with this is they would get VERY hot. So option two would be to change over to an electronic voltage free flasher. Any one used one of these. But of course all this assumes that my initial assumption (that there is just voltage getting back to the flasher).
Am I making any sense?
but I bought an LED flasher yesterday and then realised they're no good for bikes. In a car the LED flasher points straight back, as it should. In a bike indicator the LED points to the side, reducing the effectiveness.
. from hein gerkie (or how ever you spell it) for only 10quid!!!... unfortunately it is too wet out there to play with electircal stuff.. but I'll I ll tell you how (if ) it works after the next dry day.
